Re: 670 Street Avenger vs. 3310 [Re: 70duster340] #978118
04/26/11 06:49 PM
04/26/11 06:49 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Well, thank you, joedust451!!! So, everything is the same no matter what choke is in use?
According to the book yes, on the PV & jets/squirters
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 670 Street Avenger vs. 3310 [Re: 70duster340] #978119
04/26/11 10:39 PM
04/26/11 10:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
So, the only way to change jetting on a 3310 is to replace the metering block?
No, you do not have to change the secondary plate in order to change mixture. You can drill the orifices. If you move to tuning these carbs, a set of wire drills will save you a lot of money anyway.
Master, again and still
Re: 670 Street Avenger vs. 3310 [Re: 70duster340] #978120
04/27/11 11:00 AM
04/27/11 11:00 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Avenger carb has secondary metering block and jets, 3310 has metering plate ( no jets to be changed )
Depends on how old your 3310 carb is. For many years the 3310 had a metering block in the secondaries. Not sure why or when they switched to a plate. The 3310 and the 3310-1 had metering blocks and where rated as 780 cfm. The 3310-2 and newer have metering plates and are rated at 750 cfm.
Re: 670 Street Avenger vs. 3310 [Re: PowerWagonDude] #978121
04/27/11 11:18 AM
04/27/11 11:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a Street Avenger 670 on my 75 D300 360 truck. I hate it. It gets hung up on fast idle and wont kick down. It is jetted really lean so it backfires when cold or when I throttle up suddenly.
My 670 Truck avenger was really lean also. I opened up the idle restrictors to about 0.032" (I think they were about 0.028 or smaller.) That made a big difference in off-idle response because it richens up the transition circuit before the main circuit kicks in.
Re: 670 Street Avenger vs. 3310 [Re: 451Mopar] #978122
04/27/11 12:22 PM
04/27/11 12:22 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
