Proform or source roller rockers? #978055
04/22/11 01:57 PM
04/22/11 01:57 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I know theres better rockers id like to run BUT my budget will
Only allow cheaper rockers. 440 source with needle fulcrums or proform
Rockers with bushings and a adjuster upgrade? 220.00 for source or
209 for proforms and smith adjusters?? 50-60 bucks?? Ive read some
Good reviews about the source rockers. Cam is solid 250 256 560 108
Springs 350 max open
74 dart sport 440 www.Csucarbs.com
Re: Proform or source roller rockers? [Re: shoebox] #978056
04/22/11 01:59 PM
04/22/11 01:59 PM
Jamey Offline
Jamey  Offline
I really don't know much about either one, but if I had to choose I'd use the proforms with bushings. Less parts to have a failure with.
Re: Proform or source roller rockers? [Re: shoebox] #978057
04/22/11 01:59 PM
04/22/11 01:59 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Neither. Save your money for something better and keep and eye out for deals on the good stuff.
Re: Proform or source roller rockers? [Re: PorkyPig] #978058
04/22/11 02:18 PM
04/22/11 02:18 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Another budget rocker you might want to consider is CAT. I used a set for 3 years with roller cam with no issues.
Re: Proform or source roller rockers? [Re: mac56] #978059
04/22/11 02:22 PM
04/22/11 02:22 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I forgot about cAt.. Roller pressures? Cool
Re: Proform or source roller rockers? [Re: shoebox] #978060
04/22/11 02:33 PM
04/22/11 02:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Someone post a set a few days ago that looked nice for the money. Pretty sure they were Pro Comp's that might have been modified...
They were like $170 for a complete set, shafts, rockers spacers etc.
They were bushed.
Do your self a big favor, stay away from any cheap rocker that uses needle bearings...
Re: Proform or source roller rockers? [Re: Bob_Coomer] #978061
04/22/11 03:41 PM
04/22/11 03:41 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Well i think im for sure going to use bushed rockers thanks for the inputs
Re: Proform or source roller rockers? [Re: shoebox] #978062
04/22/11 03:44 PM
04/22/11 03:44 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
How about a standard Crane or Isky adjustable
rocker? I had a set on ported 452 iron heads
with an Ultradyne 590/613 cam in a 440. Street
and strip, they ran for years.
It would be nice to see or hear proof of (Source)
or (Proform) roller rockers that can outlast the
standard performance rocker. Is the H.P. that big
of a gain to make it worth it?
Snap your neck, mega G-force launch, is all I want!
Re: Proform or source roller rockers? [Re: shoebox] #978063
04/22/11 03:48 PM
04/22/11 03:48 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Have you checked www.manciniracing.com ..
They have some less expensive ones, I trust Mancini more than the Source..
Just my $0.02...
Re: Proform or source roller rockers? [Re: Sinitro] #978064
04/22/11 03:59 PM
04/22/11 03:59 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Re: Proform or source roller rockers? [Re: Bob_Coomer] #978065
04/22/11 05:59 PM
04/22/11 05:59 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Thanks for the replies. Themancini/HS bushed do look good. I dont
Know if ill have VC clearance issues w my morosos
Re: Proform or source roller rockers? [Re: Bob_Coomer] #978066
04/22/11 06:01 PM
04/22/11 06:01 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Look at these from another Post.
http://www.kmjent.com/cart/product.php?productid=445&cat=11233617&page=1
Tempting to try with some work ie adjusters / fastners hummmm
Re: Proform or source roller rockers? [Re: Bob_Coomer] #978067
04/22/11 09:15 PM
04/22/11 09:15 PM
Toronto
mshred Offline
mshred  Offline
Toronto
unless I read wrong, I believe the cheaper rockers with needle bearings use the same bearings as the Harland Sharp stuff...worth a look into it
Re: Proform or source roller rockers? [Re: mshred] #978068
04/22/11 09:18 PM
04/22/11 09:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
actually I have a set of Procomp aluminium roller rockers that have the same needle bearing pn as the harland sharp that i have....amazing..
Tony
70 AARCuda Vitamin C
Re: Proform or source roller rockers? [Re: mshred] #978069
04/22/11 09:23 PM
04/22/11 09:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
source rockers dont have caged needle bearings like harlands do...
Mopar Performance
Re: Proform or source roller rockers? [Re: shoebox] #978070
04/22/11 10:15 PM
04/22/11 10:15 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
After more research and deep digging the mancini /HS bushed
Rockers are the only option. Good adjusters good machining good
Roller tips! I wish there was some out there with miles on them
And a report card
Re: Proform or source roller rockers? [Re: shoebox] #978071
04/23/11 01:08 PM
04/23/11 01:08 PM
BDS871Cuda Offline
BDS871Cuda  Offline
And a report card
Looks like they don't offer the old standard adj.
rocker like the Crane or Isky from years back.
I think the Mancini's would be a better choice
than the (Source) rockers.
Re: Proform or source roller rockers? [Re: 70AARcuda] #978072
04/23/11 03:15 PM
04/23/11 03:15 PM
Delray beach, Florida
P
Performance Only Offline
P
wouldn't happen to have a side by side picture of that would you?
machine shop owner and engine builder
Re: Proform or source roller rockers? [Re: Performance Only] #978073
04/23/11 03:38 PM
04/23/11 03:38 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
they both had sce-146 bearing ....yes..I will see what i did with them...posted them over at FABO..
found one..Procomp is blue ...
Re: Proform or source roller rockers? [Re: 70AARcuda] #978074
04/23/11 04:07 PM
04/23/11 04:07 PM
P
PorkyPig Offline
PorkyPig  Offline
P
Those don't look like the same bearings in the Procomp and Harland Sharp, even if the races have the same number. It looks like the Procomp has fewer needle bearings.
