Re: Proform or source roller rockers?
[Re: shoebox]
#978060
04/22/11 02:33 PM
04/22/11 02:33 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Someone post a set a few days ago that looked nice for the money. Pretty sure they were Pro Comp's that might have been modified... They were like $170 for a complete set, shafts, rockers spacers etc. They were bushed. Do your self a big favor, stay away from any cheap rocker that uses needle bearings...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: shoebox]
#978063
04/22/11 03:48 PM
04/22/11 03:48 PM
Posts: 5,439 So Cal
Sinitro
So Cal
I know theres better rockers id like to run BUT my budget will Only allow cheaper rockers. 440 source with needle fulcrums or proform Rockers with bushings and a adjuster upgrade? 220.00 for source or 209 for proforms and smith adjusters?? 50-60 bucks?? Ive read some Good reviews about the source rockers. Cam is solid 250 256 560 108 Springs 350 max open
Have you checked www.manciniracing.com .. They have some less expensive ones, I trust Mancini more than the Source..
Just my $0.02...
[Re: Bob_Coomer]
#978067
04/22/11 09:15 PM
04/22/11 09:15 PM
Posts: 3,415 Toronto
mshred
Toronto
unless I read wrong, I believe the cheaper rockers with needle bearings use the same bearings as the Harland Sharp stuff...worth a look into it
