small block m1 ?? #977966
04/22/11 09:10 AM
04/22/11 09:10 AM
PA
maxwedge1 Offline OP
PA
do all small block m1 single planes have the spreadbore opening? the 1 ive seen and pics have dual bolt pattern and spreadbore plenum opening. if so is there any mismatch using holley carb?
Re: small block m1 ?? [Re: maxwedge1] #977967
04/22/11 10:32 AM
04/22/11 10:32 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i got my M1 for my 360 in 1999 and i run a 750 holley 4150, hope this helps
Re: small block m1 ?? [Re: maxwedge1] #977968
04/22/11 10:36 AM
04/22/11 10:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes.
You can change it though. We used Moroso A/B expoxy.
Re: small block m1 ?? [Re: autoxcuda] #977969
04/22/11 07:22 PM
04/22/11 07:22 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i was pretty sure mine had a different hole that was more square. i can look later since i have the carb off now. i dont really pay much attention though so i could be wrong. what ever it is its been that way for over 10 years now and i have been running it.
