dumb,but throwing it,6pk install as unit..or #977549
04/21/11 06:35 PM
04/21/11 06:35 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
pces? sounds dumb,but seems it would be easier to assemble carbs on manifold,linkage,fuel,coil,just curious what most of you do,assemble on bench,or assemble on 440 underhood? thanks for the input,thoughts,first 6pk i have installed
Re: dumb,but throwing it,6pk install as unit..or [Re: meepmeep70] #977550
04/21/11 06:43 PM
04/21/11 06:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you won't be able to torque the manifold bolts very easily.
Re: dumb,but throwing it,6pk install as unit..or [Re: mikemee1331] #977551
04/21/11 06:46 PM
04/21/11 06:46 PM
weymouth,mass.
weymouth,mass.
reason enough! thanks for reply,i thought there must be a reason one way or the other,but had to ask,because everybody that says"i scored a 6pk setup" there always assembled. your reasoning makes sense. thank you
