Page 2 of 3 1 2 3
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: StealthWedge67] #977402
04/25/11 07:22 PM
04/25/11 07:22 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Already made that swap and went back to the RPM. Much better throttle response but a tenth slower at the track. I go to the track twice a year.....easy decision.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Viol8r] #977403
04/26/11 12:58 AM
04/26/11 12:58 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a SD on a 72 440. Worked well.
Put a RPM on it and it was much better. Little bigger carb than the Holley EFI I was running, 750 vs. 700. Had much better low end with the RPM.
Running a SD on a low deck currently. I like it but can't help but wonder if that is why I seem to be down from previous MPG's from other 383s I have had with the stock intake on them.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: SomeCarGuy] #977404
04/26/11 01:41 PM
04/26/11 01:41 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Street Dominator = 455hp, 449 ft lbs
Performer RPM = 451hp, 457 ft lbs
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/index.html
....to me it doesn't look like enough difference to worry about at the 450hp level.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: therocks] #977405
04/26/11 04:40 PM
04/26/11 04:40 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
The SD is probally one of the best intakes made for a BB.I believe its about 1 inch shorter.The one I had on my 440 fits under the hood on my kids 62 300.Rocky
100%
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DPelletier] #977406
04/26/11 08:29 PM
04/26/11 08:29 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
And with that, considering that it is a street car, would'nt you want the extra hp/tq down low of the RPM?
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DPelletier] #977407
04/26/11 08:45 PM
04/26/11 08:45 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
In the article you linked to , if you only look at the peaks, they seem similar. But look at the numbers at 3000 rpm: 381 ft-lbs for the SD, 408 for the RPM. In a car with a low stall converter,I would expect the RPM to have noticably better low end than the SD. Oops, I guess I should read all the posts, not just the last few. I don't think you can directly compare the B versions of those intakes to the RB versions. I have heard more than once that the RB SD is better than the B. I suspect that the RB version is a better low end torque producer due to the slightly longer runners . Anyway.... after reading the OPs combo, I would bet that on the strip, the SD and the RPM would probably E.T. very close to each other. On the street, when you don't feel like downshifting, the RPM may be a little more responsive.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: forphorty] #977408
04/26/11 11:34 PM
04/26/11 11:34 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
First hand experience on my 71 Bee / Street car
#s 383 Mag / Balanced / .030 Over Forged / Old school Mopar 284-484 cam / 18 initial - 38 total / 3:91 Gears / Blah Blah
The 383 Holley Street Dominator off idle or launching at say 2500 rpms is a dog - That intake does not come alive until at least 3500/4000 Rpms and anything above that it flat out performs
However
The Edelbrock Performer RPM / Even just the Edelbrock Performer is just a much better intake on a mildly built 383 Mag Street Car
Like others have stated - On the 383s the Street Dominator just doesnt have the low end torque and it really shows in that Hot Rod Article and from my experience testing all three intakes on the street launching / off idle etc.
Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: forphorty] #977409
04/26/11 11:35 PM
04/26/11 11:35 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
See graph of the results below. Ron
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Ronnman] #977410
04/27/11 12:56 AM
04/27/11 12:56 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Nice Job - And pretty much what i summed up in my earlier post / first hand experience on the street
with my 383
Scott
Siberian Huskies
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Ronnman] #977411
04/27/11 10:48 AM
04/27/11 10:48 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
You need to recheck the torque and HP numbers @4000 RPM for the Torker. There is a problem there.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977412
04/27/11 11:34 AM
04/27/11 11:34 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I tried both years ago, and found very little difference between the two on my old reringed '73 440. 12.60s with the SD, and 12.50s with the RPM, MPH was exactly the same between the two...the only time it would break 106MPH is when it had wheelspin. If it hooked up, it went 106 every time no matter what I did.
RPM felt perkier at small throttle openings when driving it easy. SD was also fine, but not quite as responsive to a light touch on the throttle. I had a 4 grand converter at the time, which should cover up any differences, but it was still noticeable.
I think I liked the rpm a little better on that combo but the difference was small, can't really go wrong with either one.
Rich H.
Esse Quam Videri
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977413
04/27/11 12:33 PM
04/27/11 12:33 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
The graph info waspulled fron the following the Moparts Link:
https://board.moparts.org/ubbthreads/show...e=1&fpart=1
We have a winner: "I'll put the overall average TQ and Hp on the 6bbl, then the RPM, then the Torker."
Here's what our test showed. Each test is an average of two dyno pulls to remove anomolies. The numbers shown represent average power from 2,500 to 6,000 rpm. However, even averages do not tell the entire story. For example, the Torker and the RPM have the same average numbers, but they are not the same: the power curves cross at 3,900 rpm, with the Torker making more high-end and the RPM making more low end.
As for peak power, the Torker, Street Dominator, M1, and Victor were all at 455-456 hp at 5,900 rpm.
Nearly every manifold made 450-460 lb-ft at 3,800-4,100 rpm. Most of the dual-planes were way stronger than most of the single planes at rpm points below peak torque. Duh.
I think the tunnel ram would have done a lot better as a dual quad. I was surprised how well the Six Pack did, but I think that's because of this engine's low-rpm and low displacement. Six Packs have killed big power in other tests with other more radical engines.
That just proves that you really have to consider the test before you can make a judgment call, and you can't just look at one point of data and say "that's best" overall. It will also be interesting to see how this may change when we put better heads on the engine. If the 906 heads are currently the restriction, then other weak points in the intakes will be revealed with better heads.
More data in the December issue of HRM.
2500-6000 AVG 3000 4000 6000
INTAKE LB-FT HP LB-FT HP LB-FT HP LB-FT HP
Six Pack 428 348 413 236 459 350 391 447
Torker 427 348 395 225 455 356 397 454
Perf RPM 425 346 408 233 457 348 392 448
Victor 383 425 346
M1 single 424 345
1x4 tr 425 346
TM6 424 345
DP4B 424 344 419 239 454 346 387 442
Performer 422 341 418 238 452 344 382 436
Action Plus 421 341
Street Dom 421 344 381 217 449 342 395 452
Team G 409 334
Offy 360 406 338
Offy 2x4 408 330
Offy DP 404 327
Here are just a few data points. Also, a reminder that this thing had STOCK heads. I think the heads were the restriction, therefore the manifolds did not make drastic changes; except for the really bad ones, the different intakes just wiggled the numbers around by 5-10 hp or shifted them to the low rpm (dual plane) or high rpm (single plane). I'm pretty certain there will be more difference between the intakes once some better heads are on the engine. I find that out at the end of the month.
RPM LB-FT HP
Street Dominator
3,000: 381, 217
4,000: 449, 342
6,000: 395, 452
RPM LB-FT HP
Torker
3,000: 395, 225
4,000: 455, 356
6,000: 397, 454
Perf RPM
3,000: 408, 233
4,000: 457, 348
6,000: 392, 448
DP4B
3,000: 419, 239
4,000: 454, 346
6,000: 387, 442
Performer
3,000: 418, 238
4,000: 452, 344
6,000: 382, 436
Six Pack
3,000: 413, 236
4,000: 459, 350
6,000: 391, 447
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Ronnman] #977414
04/27/11 02:41 PM
04/27/11 02:41 PM
DPelletier Offline
DPelletier  Offline
That's a great article, but I hadn't seen the graph results before: thanks!
It's sure nice to note that the 6 pack did so well, especially since it's the only stock manifold in the test. 450ish hp is a great comparison point as it's right where alot of enthusiasts are, power wise.
I'd note that there was a follow up to this test at a higher hp level for those interested.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Ronnman] #977415
04/27/11 03:35 PM
04/27/11 03:35 PM
At the 4K point it shows the Torker as having less torque but more horsepower than the sixpack or the rpm. Looking at the formula for HP
(Torque x RPM) / 5,252 = Horsepower
you can see that at any fixed rpm if the torque is higher the HP must be higher also. Oh well not the first time a magazine goofed.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977416
04/27/11 04:36 PM
04/27/11 04:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As I had stated before we did a test on my sons low deck 400 in his Dart. Has stock bottom end with KB pistons and 10.6 comp. Its a mild 400 with the MP.557 solid cam and Eddy RPM heads. It has 3.91's as he drives the car all the time. He switched to the Street Dominator and ran 11.59 @ 117. Then he put the Performer RPM back on and ran 11.55 @ 116. Yes the RPM is better down low but not all that much. I wanted to try the RPM on my 63 but was afraid it might hit the hood so I went with the SD and I love it on my 63 as it has very good 60 ft's for a mid 11 car (best of 1.57) and I wonder if it would 60 better with the RPM. It definetly is no dog using the SD. But the good thing about the SD is that it is a very good intake and it sits very low so it will clear just about any cars hood when many intakes like the RPM wont. All in all both are good intakes. Ron
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: bee1971] #977417
04/27/11 08:36 PM
04/27/11 08:36 PM
Idaho
Runner Offline
Runner  Offline
Idaho
However
Scott
what torque converter are you running? i ran the same combo for 10 years, that cam in the 383 has more to do with it being a dog below 2500 rpm than the intake does. the more gear and converter i pit in mine the faster it went, however i started out with a dp4b intake, then tried a torker, then a tm6 and the last intake i tried was the performer rpm.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DPelletier] #977418
04/27/11 10:13 PM
04/27/11 10:13 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Dave,
I made the graph to compare the values on the same scale to visually see the advantages and short falls of the different intakes.
Thanks,
Ron
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: 383man] #977419
04/28/11 07:47 AM
04/28/11 07:47 AM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Off subject a little, but what carbs you guys running too?
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977420
04/28/11 10:00 AM
04/28/11 10:00 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Ok so we have the numbers now.. Can I run my stock kickdown and throttle cable with a Performer RPM intake.I have a Weiand now and can't find the right setup.The car is a 71 Superbee 383 column auto.Any HELP would be appreciative.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: bee71mopar] #977421
04/28/11 11:03 AM
04/28/11 11:03 AM
I think the reason that Andyf started making the taller throttle cable brackets was because of the height of the Performer RPM intake.
You can get his brackets from several online venders.
You will find what you need about 3/4 of the way down this page.
http://www.arengineering.com/throttlebracket/Tbracket/tbracketframe.html
Page 2 of 3 1 2 3
