Page 1 of 3 1 2 3
Holley Street Dominator Vs. Edelbrock RPM #977382
04/21/11 10:32 AM
04/21/11 10:32 AM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Are there any performance differences in these two intakes on a mild 440? I currently have an RPM on my motor and would like to go to the SD for added hood to air cleaner clearence. Anybody know how much shorter a SD is than a RPM?
Thanks,
'69 Barracuda 340 4-speed
'73 Cuda PROJECT
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977383
04/21/11 10:50 AM
04/21/11 10:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The SD is probally one of the best intakes made for a BB.I believe its about 1 inch shorter.The one I had on my 440 fits under the hood on my kids 62 300.Rocky
Chrysler Firepower
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: therocks] #977384
04/21/11 11:16 AM
04/21/11 11:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
They say the SD is a little softer in the bottom end and a lil stronger in the top end than the RPM. But the difference is supposed to be pretty minimal.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DaytonaTurbo] #977385
04/21/11 12:32 PM
04/21/11 12:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the street dominator with a 1" spacer and it fits under the hood of my 63 with no problems. It fit fine even when I had the flat hood on it. And the street dominator works great. It has good low eng and top end. My 63 goes 3700 lbs and has hit a 1.57 best 60 which is repectable for a mid 11 car. My son has the RPM on the 400 in his Dart and he loves it also. We ran a street dominator on his 400 and compared the two intakes. He went 11.59 @ 117 with the SD and 11.55 @ 116 with the RPM. The RPM was a tad better down low but the SD had more mph. Very close.
Here is the SD on my 440 in my 63. Ron
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: 383man] #977386
04/21/11 12:57 PM
04/21/11 12:57 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Wow, Thanks for all the great input here guys! I really appreciate it. What are the particulars on your build 383man?
'73 Cuda PROJECT
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977387
04/21/11 01:00 PM
04/21/11 01:00 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Is the Holley 300-14 the Street Dominator everyone is talking about that you can still buy new? For some reason I thought they were discontinued and you had to find a used one?
300-14 Street Dominator
'73 Cuda PROJECT
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977388
04/21/11 01:15 PM
04/21/11 01:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
.030 over 440 with stock bottom end and KB quench pistons that give me 10.0 comp with my 906 heads I ported. MP .557 cam and Comp dual valve springs. SD intake of course and a 850 DP. Hedman 1-3/4 headers and 3" pipes. 727 with Dynamic 9.5 converter and 4.30's with 30 x 9 tires. 11.49 @ 116 best but I am building a 493 stroker as we speak hoping to get in the 10's and still be a pump gas eng. Ron
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977389
04/21/11 03:31 PM
04/21/11 03:31 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
IIRC, the Street Dominator for the RB is still being produced and the one for the B you have to find used.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977390
04/21/11 05:30 PM
04/21/11 05:30 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
I really like the Holley Street Dom intake; very good/even fuel distribution and fuel atomization. Work great with spread-bore or square-bore carbs!
I have this one on my stock '68 440 non hp with TTI 2" headers and 727 trans with stock low stall converter. Was running a 3.91 SG and it would
light-the-tires but switched to a 2.94 SG and it will still light-the-tires! Lost of low end power with my '70 Comp 850 T.Q. carb.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DEMONSIZZLER] #977391
04/21/11 08:51 PM
04/21/11 08:51 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
A lot of these engines are not "mild"! Go with the RPM.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977392
04/21/11 10:29 PM
04/21/11 10:29 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
Alright want some real numbers go to moparmusclemagazine {tech articals} under Intake Exstravaganza.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977393
04/21/11 10:42 PM
04/21/11 10:42 PM
tucson az
frank Offline
frank  Offline
tucson az
I don't have a comparison but I have a SD on my 496 so as to use the stock hood. The egine made 636.9 pounds of torque at 4300 rpm and 567 hp at 5400 RPM. This manifold works.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: frank] #977394
04/21/11 10:55 PM
04/21/11 10:55 PM
Central NC
gch Offline
gch  Offline
Central NC
Yes the intake works.However on a mild 440 I would opt for the added low end grunt of the dual plane rpm.ANother place where the rpm is likely better on a mild motor(or in a heavy car with mild gearing)is part throttle response.You see a lot of part throttle on the street.
I am a big fan of the intake(I have run it on my 496 and my 465),just not on stockish builds with medium gears and full weight cars.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: DEMONSIZZLER] #977395
04/21/11 11:12 PM
04/21/11 11:12 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
It's both the carb and the manifold. The TQ
gives better atomization at low/midrange. The SD
just ENHANCES the mixture and it flows stronger!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: HYPER8oSoNic] #977396
04/21/11 11:59 PM
04/21/11 11:59 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
30 years ago I took a two bbl off of a 400 in a van and put the street dominator on it with a holley spread bore 650 VS and it was like adding 100 cu inches!
It really worked on it, mileage went up, drivability too. Tire wear did suffer though!!!
I could get 17 mpg instead of 14, and spin tires at 30 mph punch.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: fox] #977397
04/22/11 04:40 AM
04/22/11 04:40 AM
Holland MI Ottawa
2
2boltmain Online content
2boltmain  Online Content
Holland MI Ottawa
Small plenum single planes work well on even mild engines. The big block SD is the best of them. An original advertisement for the Torker 440 claimed the "New" (1974 ad) Torker single plane manifold when bolted on to the emissions choked Dodge and Plymouth big blocks brought back some of that lost power. Then the add went on to say if you bolted the Torker to a 67-71 engine..."WOW!"
Keep old mopars alive.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977398
04/25/11 01:42 PM
04/25/11 01:42 PM
Johnson City, TN
Haney Offline OP
Haney  Offline OP
Johnson City, TN
Here is my build that I am calling mild:
• 71 440
• Stock rods and crank
• TRW Forged Flattops; approx. 10:1 Static Compression ratio
• Out of the box Edelbrock RPM heads (84cc)
• Stock style rocker gear
• Comp XE285HL Cam, comp lifters,
• RPM Intake
• 750 Speed Demon Carb
• MP Electronic Ignition
• Doug’s 2” Full Length Headers
• 3” Magnaflow bullet mufflers out the side like a AAR currently, coming a 2 ½ “ X-pipe exhaust system. Current system way too loud.
• 833 4-speed
• 8 ¾” rear 3.91 sure grip
• 275/60-15 rear tires (28” tall)
I may eventually change the cam to a bit smaller one to get better idle characteristics. Thinking on the Luntai 60303. Also may add a BIGS 850 DP or Proform 850 DP. Other than that, this is what I have. The RPM, because of height and stock hood, limits me on air cleaner space. If I would not be doing anything stupid to rob me of significant bottom end, then I would like to change to the SD.
Thanks,
'73 Cuda PROJECT
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: Haney] #977399
04/25/11 03:16 PM
04/25/11 03:16 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I would put an SD on that combination in a heart beat. You will not be disappointed.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977400
04/25/11 04:06 PM
04/25/11 04:06 PM
Central NC
gch Offline
gch  Offline
Central NC
That combo will like the sd alot.The idle will be better with the dual plane but other than that the combo will respond well to the sd.Run plenty of initial advance and it will help the idle also.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: gch] #977401
04/25/11 04:23 PM
04/25/11 04:23 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
That combo will run good on the street, especially with the 750 carb. If you want to make the most of the SD single plane, Eddy heads, and 2" headers however, which all will allow a 440 to breath north of 6k, you may want to think about a bigger carb. The 750 will likely start costing you power at around 4500 - 5000. But as said, it will likely run crisper around town than an 850 would.
Page 1 of 3 1 2 3
