Re: Repro fuel sender problems.
[Re: Kern Dog]
#977272
04/21/11 09:33 AM
04/21/11 09:33 AM
Posts: 416 Franklin Co. Illinois
runinonmt
I suspect a sinking float but no matter what you do the sending unit will have to be removed. pop the float off and shake it to see if it has any fuel in it. If it does you have the choice of a brass stock float or a plastic Ford#COAZ-9202-B If that's OK check the resistor with an ohmeter. 10 full,70 empty. Adjusting this is beyond my ability but a thread ran a while ago about grounding the resistor to the body of the sending unit. Hope this helps, Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: runinonmt]
#977273
04/21/11 10:00 AM
04/21/11 10:00 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I swapped out to the new 3/8 unit...and I am probably going to put the 5/16 unit back into my tank...Reason being for the same problem you are having...Plus I figure since the rest of the hard line from the tank to the engine bay is factory....a 3/8" in the tank is useless...like shoving a tennis ball through a firehose....it could eventually get through but with great resistance.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Dabee]
#977275
04/21/11 11:47 AM
04/21/11 11:47 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
most of the cars i see have this problem , i have restored three b bodys and all do the same thing 5/16 , 3/8 does not matter . i have replace the wire from the back of the guage cluster to the sending unit , made sure the sending unit is grounded and changed floats to brass from plastic . this all had no effect on the guage , reading ! Here is the weird part , if you hold the dang thing in your hand with all the connections made i can move the float by hand and make it go full and to half when out of the tank . Unbeliveable right I know! my take on this is some thing has been lost from the factory units to the aftermarket , either wrong calibration OR the float hits the top of the tank when inside the tank so it will never read full .
someone said you have to bend the arm on the sender, i don't know if this works or not . might be worth a try bending it down so it will rise higher in the tank .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#977278
04/21/11 03:32 PM
04/21/11 03:32 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
For me it wasn't a matter of bending the arm, it was bending the upper stop tab so the arm would swing a teeny-tiny bit farther.
Worked like a charm in my case.
Like investing in the stock market, your results may differ.
[Re: cjs69mope]
#977279
04/21/11 04:44 PM
04/21/11 04:44 PM
Pyper70
Athens, Greece
I went overkill for my sending unit...I have the original 5/16" unit which I am popped out for a 3/8". Both setups were installed the same way. I have a 14gauge wire soldered to the sending tube below the rubber hose. From there it goes to its own dedicated ground on the frame. I ran a wire all the way from the sending unit, into the harness, and to the old fuel gauge.
With my old gauge it worked but I had restored a second cluster professionally and it still came up just below full tank. This was about the time I swapped units.
I have a brand new brass float from a Ford thats a perfect match for it. Should get around to doing that task soon. Would like to have fuel when I am driving
[Re: Kern Dog]
#977280
04/21/11 06:48 PM
04/21/11 06:48 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I remember that in previous posts about testing sending units, some have written that the rheostat (?) should show a certain reading at FULL and another at EMPTY.
don't hold me to it but i think it was rapidrobert who explained how to adjust this.
