Here is what i have a 1966 plymouth satellite with a 440 & indy sr heads i just put a set of TTI headers WOW best money i ever spent they where so easy to go in from under the car.!
1. But here is what i face now with these headers its very tight for my trans lines does anyone know of some good flex trans lines i could use.
2. i am using a scs cheetah shifter its set back for easier reach has anyone out there put one of these in a 66-67 sate/belevedere if so how far forward did you have yours and how did you run the shifter cable to keep it away from the exhaust.! i know its going to be a tight fit.!
I just want to see if some one out there has faced the same thing.!
