The one in my pic is the correct piece..The all metal pieces are the aftermarket replacement units..Actually the bakelite unit was used for a broad range of cars and trucks and the ones out there are actually NOS mopar replacements that are still floating around...the mopar replacement kit had the bakelite valve and 3 different brackets to cover the broad applications..so while a vendor might act like he's doing you a favor supplying a peticular bracket they're actually keeping the other two from the kit...
...The pic in your {mopars by crane}link is the correct valve but the supplied bracket with it is the C body piece...This would be the correct 70-71 piece..
water valve bracket Like I said take your time and watch for them on the bag...If you pay more than 150 you're in too much of a hurry..
Valves like
THIS are on there every week...Use keywords "mopar water valve", Mopar heater valve, AC valve, and the usual 70 challenger,cuda, etc...
