Piston Ring Question for Rebuild #976930
04/20/11 12:18 PM
04/20/11 12:18 PM
Beautiful Downtown Bahama, NC
tact1 Offline OP
tact1  Offline OP
I am freshening my 400 stroker and need new rings. Is there an advantage or disadvantage in using a low tension oil ring? I don't use nitrous. Thinking of a plasma moly faced ductile iron top ring, reverse twist second (iron) and standard tension oil ring. So many makers. I'm using Ross pistons. Recommendations?
"Four out of three people have a problem with fractions"
Re: Piston Ring Question for Rebuild [Re: tact1] #976931
04/20/11 01:56 PM
04/20/11 01:56 PM
Don't use low tension oil rings n a street motor, unless your running a vacume pump on the crankcase I don't use the low tension oil rings on my race motors without a vacume pump either
Re: Piston Ring Question for Rebuild [Re: tact1] #976932
04/20/11 01:56 PM
04/20/11 01:56 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Whats the application? Intended use? You can defiantly tell a diff turning the same engine over by hand using low tension oil rings, then same engine with standard oil rings.
So theoretically there is some power to be gain by friction loss.
I run a vacuum pump with low tension oil rings to help control the ring seal.
If this is not a all out effort type engine deal forget the low tension oil rings.
Re: Piston Ring Question for Rebuild [Re: Bob_Coomer] #976933
04/20/11 05:20 PM
04/20/11 05:20 PM
Az
Crizila Offline
Crizila  Offline
Az
add
Fastest 300
Re: Piston Ring Question for Rebuild [Re: Crizila] #976934
04/20/11 05:30 PM
04/20/11 05:30 PM
tact1 Offline OP
tact1  Offline OP
I saw some rated at 18 pounds(low tension) and some at 23 for standard tension, so Ill just go with standard. I don't have a pump, don't use nitrous, don't drive it on the street. Compression is 12to1
