727 shorty ?s #976887
04/20/11 11:48 AM
04/20/11 11:48 AM
scratchnfotraction Offline OP
on a 727 shorty with bolt on yoke,do you just remove the yoke and tail housing bolts and it comes off?
or does it have a snap ring like a long tail shaft housing?
also..to remove the low/rev lever pivot pin,do you just remove the tail housing and then it drives out the back of the case?
TIA
Re: 727 shorty ?s [Re: scratchnfotraction] #976888
04/20/11 11:53 AM
04/20/11 11:53 AM
La Grange, Ky
70rrclone Offline
70rrclone  Offline
La Grange, Ky
you have to take the guts out to get the snap ring off. i just went through this converting a shorty with e brake to a long tail.
are you trying to convert this to a long tail?
or maybe i missread are you talking about the support bearing snap ring? i dont remember there being one on the short tail.
shane
Re: 727 shorty ?s [Re: 70rrclone] #976889
04/20/11 11:55 AM
04/20/11 11:55 AM
no,just want to R&R the pivot pin for the low/revs lever
Re: 727 shorty ?s [Re: scratchnfotraction] #976890
04/20/11 12:30 PM
04/20/11 12:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
