04/20/11 09:41 AM
04/20/11 09:41 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
How can I tell if a 413 is just a regular 413 or a max wedge engine?
Re: 413 [Re: buck0123] #976789
04/20/11 09:43 AM
04/20/11 09:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
odds of it being a max wedge wold be about 0 to none.
Re: 413 [Re: MoparforLife] #976790
04/20/11 09:44 AM
04/20/11 09:44 AM
houston texas
gremlinsteve Offline
houston texas
read up on casting numbers.
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 413 [Re: gremlinsteve] #976791
04/20/11 10:13 AM
04/20/11 10:13 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
block casting number 2205697-2/ head casting number 2406516-3
date 1-6-64
Re: 413 [Re: buck0123] #976792
04/20/11 01:07 PM
04/20/11 01:07 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
http://www.cowtownmopars.com/CastingNumbers.html
Here's a link, looks like you have a regular ol 413.
Re: 413 [Re: buck0123] #976793
04/20/11 01:52 PM
04/20/11 01:52 PM
block casting number 2205697-2/ head casting number 2406516-3date 1-6-64
Thats a passenger car motor, non Hi Po 413 Max Wedge motors where 1962 only, they had the short cross ram with the dual Carter 3447 carb. numbers, adjustable rocker arms and so on, Max Wedge heads where the same casting number in 1962 and 63 and they had four bolt valve covers only
Re: 413 [Re: Cab_Burge] #976794
04/20/11 02:49 PM
04/20/11 02:49 PM
houston texas
houston texas
rebuild that thing. turn her into a 426 and toss some maxie heads from indy on it...should be a fun project when done.
steve
