Firm Feel steering box questions... #976507
04/19/11 07:00 PM
04/19/11 07:00 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I have read from several members about how happy many are with their rebuilt steering gear chucks. I had one rebuilt back in, oh.. 2003 or so. I opted for the Stage 3 rebuild. I used to own a Camaro that was set up for handling. It had HD springs, shocks, anti sway bars and an IROC 12.7 to 1 steering gear. I loved the steering feel and response of that car and wanted to duplicate it with my Charger. The Stage 3 was purported as being nearly as stiff. It was not. While it gave more effort than the usually overboosted Chrysler power steering, it was still not to the point that I wanted. I later added the Fast Ratio idler and pitman arms, and THEN it felt right. Lately it seems that the gearbox has loosened up to the point where it has a sloppy "dead spot" from 11 to 1. (Using a clock as a reference point)I can't imagine that the set screw has backed off, but who knows. The car has TTI headers so adjustments are not an easy thing to do. I am curious if other Firm Feel customers have had this problem. When I first installed the box way back when, it felt as tight as a new car. Now, lane changes or sudden maneuvers take more turning of the wheel and less "feel". NOT good. I'll take the time and try to adjust out the slop, but it seems that in some cases, once wear begins, its all downhill from there.
Re: Firm Feel steering box questions... [Re: Kern Dog] #976508
04/19/11 07:04 PM
04/19/11 07:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think the problem is that the boxes are just rebuilt. The old gears are used again. And the gears wear in certain spots, rather than evenly. Maybe you could tightly the lash again. Try giving Dick Ross a call at Firm Feel for suggestion.
Maybe if they started making new P.S. boxes like they do you manual boxes, we'd have a better solution.
Re: Firm Feel steering box questions... [Re: Kern Dog] #976509
04/19/11 07:15 PM
04/19/11 07:15 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
First I'd suggest you check to see where the slop is, i.e. the coupler, box-the mounting bolts can loosen up, and even cause flexing on the K member. I didn't notice any problems with my stage 2 box , but have replaced 3 idler arms after installation. I've got 255/50-17s on the front of my barracuda, with a late K-member IIRC '75.
Re: Firm Feel steering box questions... [Re: Skeptic] #976510
04/19/11 08:53 PM
04/19/11 08:53 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'm a mopar guy but come on...You won't get that IROC camaro feel out of the firm feel box and old sheetmetal... At least not without some major mods... Seriously though, as Steve has suggested if the parts were somewhat wore to begin with who knows....And checking the K and box out is right on track also.... ... There was a post where you can put a restrictor inline at the pump which does get you closer to the feel you're after {assuming you address the slop issue}...I think the discussion came out of a Mopar Action article a year or so ago...I remember reading the article....EDIT: I do remember one box I recieved from them where that adjuster nut was loose...It did move on the road test and I felt the slop you're describing but it was leaking out the adjuster so that was a quick give-away on that problem...
Re: Firm Feel steering box questions... [Re: Skeptic] #976511
04/19/11 08:54 PM
04/19/11 08:54 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Agreed, check the steering gearbox to K-member bolts. If you are running sticky tires with the fast ratio pitman arms it will work the box loose if you don't have the K-member reinforced. I run sticky 245/45/17's on my challenger with the FF box and the T/A fast ratio steering and had to tighten it up periodically. Its not a problem though if you aren't running the sticky tires and pushing it hard though.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Firm Feel steering box questions... [Re: blown340] #976512
04/19/11 09:01 PM
04/19/11 09:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
-Jon
Someone here or on another list had loose steering gear bolts recently. He thought they were fine and he checked them. But he went back and spotted the loose ones.
Re: Firm Feel steering box questions... [Re: screamindriver] #976513
04/19/11 09:06 PM
04/19/11 09:06 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm a mopar guy but come on...You won't get that IROC camaro feel out of the firm feel box and old sheetmetal... ...
But he was just saying it's not like it was when it was newer/new with the fast ratio arm installed. Something seems to have changed.
How many miles are on the steering box?
Re: Firm Feel steering box questions... [Re: autoxcuda] #976514
04/20/11 01:40 AM
04/20/11 01:40 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I've put less that 2000 miles on the car since I first put the FF box in. Yeah, I know... REAL car guy, right? Okay, okay, I should get out and drive the car more.
YES, I have large, sticky tires on the car: 275-40-18 Nitto 555. I have thought that I probably should gusset the steering box mount on the K member. I'll check things out and report back. Thanks for the suggestions.
Re: Firm Feel steering box questions... [Re: Kern Dog] #976515
04/20/11 02:14 AM
04/20/11 02:14 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Not to Hijack but, wasn't there another outfit competing with Firm Feel a few years back? I want to say they might have been called "Steer and Gear" ?
Re: Firm Feel steering box questions... [Re: screamindriver] #976516
04/20/11 02:35 AM
04/20/11 02:35 AM
hooziewhatsit Offline
Must be referring to this thread?
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6125180
To the OP, how quick is it to drop the drag link and see if you can 'rattle' the end of the pitman arm? My truck was horrible before I snugged it up
Re: Firm Feel steering box questions... [Re: hooziewhatsit] #976517
04/20/11 03:31 AM
04/20/11 03:31 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The center link pops loose with a pickle fork in less than a minute. Good idea.....
Re: Firm Feel steering box questions... [Re: Kern Dog] #976518
04/20/11 08:52 AM
04/20/11 08:52 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes you do, and you likely are in a very select group here with that much front end tire on a old mopar.
Re: Firm Feel steering box questions... [Re: jcc] #976519
04/20/11 09:48 AM
04/20/11 09:48 AM
Texas
vynn3 Offline
vynn3  Offline
Texas
Yeah, and I bet it looks GREAT!
Re: Firm Feel steering box questions... [Re: vynn3] #976520
04/20/11 02:20 PM
04/20/11 02:20 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Wow. whats this? POSITIVE responses instead of calling my car a DONK? Is this REALLY Moparts ?
Re: Firm Feel steering box questions... [Re: Kern Dog] #976521
04/20/11 03:09 PM
04/20/11 03:09 PM
san diego
JonsGottaDusta Offline
san diego
I want pics
Re: Firm Feel steering box questions... [Re: Kern Dog] #976522
04/20/11 05:51 PM
04/20/11 05:51 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Ok, if you miss it. Your cars a over heating DONK (what ever that is?)!
Re: Firm Feel steering box questions... [Re: bigblock340power] #976523
04/20/11 07:23 PM
04/20/11 07:23 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I haven't overheated this car ever. I HAVE vapor locked a few times SEVERAL years ago though.....
Re: Firm Feel steering box questions... [Re: Kern Dog] #976524
04/20/11 07:24 PM
04/20/11 07:24 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Number two
Re: Firm Feel steering box questions... [Re: Kern Dog] #976525
04/20/11 11:26 PM
04/20/11 11:26 PM
Harrisburg, Pa.
Harrisburg, Pa.
Great looking ride !! ...That wheel/tire combo looks right at home on there...Hard to believe they're actually as big as they are and not look out of place...
Re: Firm Feel steering box questions... [Re: screamindriver] #976526
04/24/11 03:16 AM
04/24/11 03:16 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I got a chance to look closer today. The stub that the steering column shaft slides onto... Moves in and out by at least 1/8" as it rotates within the freeplay range. I tightened up the adjustment screw, but the slop remains. Zero leaks though. The mounting bolts are tight. No slop in any of the tie rods or center link. I have at least 6 or 7 spare power steering gearboxes here to swap in, but I am pissed that THIS "rebuilt" box cost me around $300 including shipping. (Only 2 states away) Why would it develop so much slop within only 2000 miles? I can't expect any sort of warranty since I put it in in 2003. Still, if factory units held up for 80-100 thousand miles, why should a rebuilt one from a reputable company wear out so quickly?
I think that Steve made a good point. These units may be getting nothing more than a good cleaning and new seals. What a shame.
