EGR valve 95 Dakota #976428
04/19/11 03:24 PM
04/19/11 03:24 PM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
I had a trouble code with my 95 dakota indicating the EGR wasn't working. I took one off my 3.9 V6 and put it on the 5.2 V8 and the engine seems to run fine. I noticed that the V6 and V8 use two different EGR valves however and wondered what the difference was. Do I need an operational EGR and am I losing performance by using the V6 EGR?
Re: EGR valve 95 Dakota [Re: pengwin] #976429
04/19/11 07:19 PM
04/19/11 07:19 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is possible that the 'pintle valve' on the 3.9V6 version is smaller to limit EGR flow at mid throttle.
There is also a nearby 'EGR Modulating Valve' that pulses the vacuum to the actual EGR valve to control the amount of flow. This EGR Modulating Valve also has an exhaust backpressure port meant to keep the EGR flow off until you get to mid throttle power levels.
The EGR is turned off at idle,
and at wide open throttle
... it is used in the middle throttle positions to cool peak combustion temperatures and limit NOx pollution emissions
I have cleaned out the cast-in-place EGR passage inside the aluminum intake manifold by
first packing and turning off the truck on a hill with the front of the truck highest up the grade,
then using a long plastic tube and spraying Chrysler Combustion Chamber cleaner into the two sideways holes underneath the throttle body blades, letting the solvent flow back down the passages and hopefully begin loosening the carbon deposits,
waiting 20 minutes to let the solvent do its work,
then starting the truck up
and watching the black smoke cloud come out the tailpipe.
The steel tube from the exhaust manifold up to the bottom of the EGR valve can also become plugged.
If the spark plugs are in good shape,
EGR is supposed to slightly improve MPG at highway cruise.
If the spark plugs and ignition system is not in tip top shape,
EGR can make mis-fires more likely,
and can hurt MPG with each mis-fire.
The EGR valve for a 1995 5.9 V8 was $134 at the dealership about 8 years ago.
Re: EGR valve 95 Dakota [Re: 360view] #976430
04/19/11 10:21 PM
04/19/11 10:21 PM
Oxford, OH
Blue93Dakota Offline
Oxford, OH
I deleted mine all together. Just left all the hoses and controllers in place and plugged in. Took the two hoses off the valve itself and looped them together. Blocked off the manifold and the header. No CEL and it ran well. No noticeable differences.
93 Dakota Club Cab R3 Turbo Build in progress
