Hemi Stroker - fuel pump #976084
04/18/11 09:40 PM
04/18/11 09:40 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Well, over the weekend I started the FHO built sroker Hemi in the Cuda.
And quickly found of the fuel pump is toast ( sitting 5 years I guess was not good on it )
Whats a good pump to install on a mild build Hemi. mechanical only please.
I want to think there are/were more than one possibile Hemi style pump with 1 being better / higher quality than the other.
The stock 3/8" hose inlet nipple and 5/16" threaded outlet is a must as well btw
Re: Hemi Stroker - fuel pump [Re: gtx6970] #976085
04/19/11 04:15 AM
04/19/11 04:15 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Bill:
The standard Hemi pump is fine for 600 plus HP. I truly cant say what the limit is for mechanical pumps like those, but most people go way overboard with fancy fuel systems and 1/2" lines on motors that barely make 500 hp.
MB
