Tach is bouncing all over the place..... #975855
04/18/11 03:56 PM
04/18/11 03:56 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
its a aftermarket sun tach, checked my ground, all the connections, made sure it connected to + on the coil. what gives?
Re: Tach is bouncing all over the place..... [Re: AK_JH27] #975856
04/18/11 04:23 PM
04/18/11 04:23 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
What kind of ignition system are you running?
Some tachs jump around with multi-spark ignitions.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Tach is bouncing all over the place..... [Re: 340727dart] #975857
04/18/11 04:47 PM
04/18/11 04:47 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
I dunno if this helps but this is what happened to me.
https://board.moparts.org/ubbthreads/show...e=0#Post6286480
Re: Tach is bouncing all over the place..... [Re: 2734bbl] #975858
04/18/11 05:59 PM
04/18/11 05:59 PM
Minnesota USA
Dart6pak Offline
Dart6pak  Offline
Minnesota USA
A tach should be wired off the - negative on the coil on stock ignition
There are some articles stating not to connect to the negative if you have an MSD setup.
