universal radiator mounting question #975837
04/18/11 03:31 PM
04/18/11 03:31 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
So I have a nice pretty griffin universal 26" radiator for my project... 22" core, no big deal to me..
Should I center this up in the core with even space overlapping the left and right of the core support? Or should I center it up to the water pump on the engine?
I am running an electric fan as well.
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: universal radiator mounting question [Re: jpilone] #975838
04/18/11 03:58 PM
04/18/11 03:58 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Because you can mount the electric fan any where on the rad, I would center it in the core support opening.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: universal radiator mounting question [Re: bigsbigelow] #975839
04/18/11 04:13 PM
04/18/11 04:13 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
But what about radiator hose fitment? I'm assuming I'm going to have a challenge on my hands and a stock-type hose won't work...
-Jarrod Pilone
My Project Thread
Re: universal radiator mounting question [Re: jpilone] #975840
04/18/11 10:42 PM
04/18/11 10:42 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
Bump for the evening crowd
-Jarrod Pilone
My Project Thread
Re: universal radiator mounting question [Re: bigsbigelow] #975841
04/18/11 10:58 PM
04/18/11 10:58 PM
to get the most (air) flow and www.speedwaymotors.com (a mile away from me) has metal rad hose extensions (straight or curved) w the rib on each end so you can cut hoses to get the routing you need
Re: universal radiator mounting question [Re: RapidRobert] #975842
04/19/11 08:34 AM
04/19/11 08:34 AM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
http://www.speedwaymotors.com/Radiator-Hose-Kit,46325.html
That is exactly what I was thinking!
I can get my friend who painted the car paint these tubes up and put some subtle, yet very killer, graphics on them too!
-Jarrod Pilone
My Project Thread
Re: universal radiator mounting question [Re: jpilone] #975843
04/19/11 10:31 AM
04/19/11 10:31 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
either way you do it , use a fan shroud that covers all of the radiator core if possible. i have had problems before with electric fans and the car getting hot. each time i tossed the shroud that came with the fan since it didnt cover all of the core and made one to cover it all and it always fixed the problem and ran cooler.
also i have had a lot better luck with the fan on the engine side not in fromt of the radiator.
just a little advice you may or may not have allready this stuff before
Re: universal radiator mounting question [Re: dirt] #975844
04/19/11 10:58 AM
04/19/11 10:58 AM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
The fan I've got covered. I have a OEM Chevy HHR fan with a nice shroud on it that fits the core perfectly, and a painless wiring fan control for it to boot!
-Jarrod Pilone
My Project Thread
Re: universal radiator mounting question [Re: jpilone] #975845
04/19/11 02:16 PM
04/19/11 02:16 PM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
Also, you might want to make sure you have clearance for your battery tray. I ran into this on my 70 Coronet and ended up having to notch the tray to get it to fit. It's not a big deal -- just something to look out for.
1970 Dodge Coronet 1968 Barracuda FB 1970 Duster 1974 Dart 1977 Dodge Custom Van
