Page 2 of 3 1 2 3
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975499
04/19/11 03:48 AM
04/19/11 03:48 AM
Does it have to be 383? A 440 would get you there so much easier.
I am currently out of 440s, except the finished solid lifter done 500 stroker I have sitting in the shop, that was originally for a drag car that I wont be using now. My engine builder believes that its best to use that motor for what it was intended to be for or sell it or trade it for a done motor for this car. So I was hoping to build the 383 that I have.  But This is why I am posting the thread. To weigh out my options.RUMBLON
Can you get a stock stroke forged steel BB crankshaft that is not turned on the rods? If so you can build a really nice street stroker using a BB crank(fairly inexpensive with a good shop, you will need to turn the mainss down also to stock 383 sizes ) and have it offset ground to BB Chevy rod sizes with a 3.91 or 3.90 stroke, 6.8 or 6.7 long BB chevy H beam rod and a custom piston with a dish or reverse dome fo compression under 10.0 to 1 , not above with stock close chamber iron heads If you decide to go with a set of new aluminum heads then shoot for 10.0 to 10.7 to 1 compression for premium pump gas I don't have the exact C.I. for a 4.280 to a 4.310 bore with a 3.91 stroke but I'm sure it is near 450 C.I., lots of torque and good HP And it lloks stock
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975500
04/19/11 11:04 AM
04/19/11 11:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
RUMBLON
Why not just change the cam and the intake on that motor and use it if you have no intention of doing a drag car now ? It would be alot cheaper than building a new engine and you are going to end up selling that 500" engine for pennies on the dollars you spent building it. Of course this is ASSuMEing it's not a 13.0 compression engine.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975501
04/19/11 11:15 AM
04/19/11 11:15 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
And so what if it is 13-1? It would still be much cheaper to change pistons in this one than to build a whole new engine that would have a lot less potential.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975502
04/19/11 12:01 PM
04/19/11 12:01 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
build a nice torquey 383 stroker. 450hp out of a stock stroke 383 isn't necessarily "streetable" depending on what you really mean by that. Does "streetable" mean "the ability to drive the car on the street" or does it mean a mellow idle, high vacuum, pump gas motor that doesn't have to be revved to the moon to make decent power?
For the stated purpose, if I was trying to keep the costs down, I'd spend the money on the stroker kit before the heads....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: DPelletier] #975503
04/19/11 12:14 PM
04/19/11 12:14 PM
California
court9155 Offline
court9155  Offline
California
How about just use the 383 with a good balance job
Put these pistons in it:
http://www.summitracing.com/parts/SLP-WL2315F30/
Fresh 906s with good valves and springs (little extra coin from them):
http://www.aeroheadracing.com/id6.html
Hughes whiplash cam:
http://www.hughesengines.com/Index/produ...mp;partid=25115
And this with just 100HP jets:
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=192
Should make 450hp
I know I love the sound of this cam at idle and it is supposed to be ground to cater to low compression.
Ill let you know how this works because it is the EXACT combo that I am going to run unless PROBE makes there new pistons with the 5/64 rings and two valve reliefs (supposed to be ligther) for a 4.280 bore and 3.375 stroke with stock rod length
67 charger
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: court9155] #975504
04/19/11 12:44 PM
04/19/11 12:44 PM
DPelletier Offline
DPelletier  Offline
everbody knows that nitrous doesn't count!
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: GomangoCuda] #975505
04/19/11 12:45 PM
04/19/11 12:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You forget, more than likely, having to rebalance for the heavier piston.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: court9155] #975506
04/19/11 12:49 PM
04/19/11 12:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should make 450hp
He can get the same lackluster heads for less at a local shop with just a rebuild of cores he has, plus I wouldn't use 906's because of the open chamber design.
If you are starting from scratch as it sounds you are find some 915 heads .
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975507
04/19/11 12:52 PM
04/19/11 12:52 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Open to Eddys or source heads.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RemCharger] #975508
04/19/11 12:55 PM
04/19/11 12:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The OP is open to EDDY's , he said so in his original post .
For a fresh build from scratch if one is not building for a specific class of racing , or just wants to retain factory parts , new alum heads would be the way to go .
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975509
04/19/11 01:00 PM
04/19/11 01:00 PM
California
court9155 Offline
court9155  Offline
California
Should make 450hp
heads .
Lackluster lol, maybe to a guy that already has or has had several 450hp plus motors but to most guys the results will be far from lackluster. There is always a better way to build a motor or a cheaper way or this, that etc.
My post was more or less meant to throw an idea out there. Not the ultimate B block 450hp build. Mine was more budget minded.
Aerohead will build 915s for 100 AND they will install better exhaust valves (for the nitrous) like some manley extremes for a tad bit more money too.
I put some 906 heads on my buddies car and they looked nice and performed very well for an as cast 906. Sure they didnt make 450hp but they ran well and the motor sounded good.
Next best thing would be 440source heads (budget minded) but they dont come with nice manley or ferrea valves. They come with ok valves. I also dont like the way the seats are machined. I know I have a set and had them fixed. Ended up being into them almost 2,000 dollars.
I was just throwing it out there (using a little nitrous)......... and to be honest with the nitrous it wont really matter what heads and compression he has when the button is pushed
Dan
Oh and nitrous does count! LOL how do you think the chevys keep up!!
hahaa just kiddin.
67 charger
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: court9155] #975510
04/19/11 01:09 PM
04/19/11 01:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should make 450hp
heads .
Dan
hahaa just kiddin.
Dan you have obviously not seen the posts about aeroheads and their quality or lack there of , that is why I say lackluster , there is nothing special about what they do , just a standard valve job , and it's been said to not be very good . with that in mind , and core charges AND shipping half way across the country you can do better LOCAL .
906's with the open chamber are a BAD choice, I use them because I HAVE TO, not because I want to, so I have a lot more money tied up in cylinder heads than I really should.
I've got 3 pairs of 906's, one set pure stock legal ... $1200, one set with very mild port work that had been worked on twice because the first shop made them flow worse ... $1600, then a set that are a stage 2ish port job, that started off as a backyard template job that wasn't very good, $1500 ... If I had to sell them I'd be lucky to get 50 cents on the dollar for what I spent.
I have a set of 915's that will end up on the stock 383 once I get the pure stock bug out of my system.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975511
04/19/11 01:12 PM
04/19/11 01:12 PM
California
court9155 Offline
court9155  Offline
California
Should make 450hp
heads .
Dan
hahaa just kiddin.
No, I haven't seen the post about Aerohead...wow. The one set of 906s my buddy bought from them seemed to work great.
Thanks for the heads up, Ill check into it.
Thought that maybe this one time the rule, you get what you pay for, could be broken.
If thats the case, I guess 440 source heads are gonna look better and better to him.
Dan
67 charger
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975512
04/19/11 01:35 PM
04/19/11 01:35 PM
Didn't forget. Why would the lower compression pistons be heavier? Diamond flat top or dish piston is lighter than Diamond Dome piston. Same with Ross. It won't cost any more to rebalance the 500 than it would to balance the 383 so that is a wash.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: GomangoCuda] #975513
04/19/11 01:48 PM
04/19/11 01:48 PM
IL
furious70 Offline
furious70  Offline
IL
you could pressurize the intake on a 383", use a creamy smooth cam and have plenty of streetability.....
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: furious70] #975514
04/19/11 02:03 PM
04/19/11 02:03 PM
California
court9155 Offline
court9155  Offline
California
Very true....S300s on sale as well as S400s
I have used VRracing for a few turbo purchases and some misc. turbo parts and I was very happy with the price, shipping and customer service.
http://www.theturboforums.com/smf/index.php?topic=147425.0
Me, personally, there is nothing like the sound of an old school motor with better than 9.5 to one compression and a healthy cam.
My turbocharged 6.0 LS chevy motor in my fox body mustang with garret turbo made insane power but sounded like a 318 2 barrel with cats on it, underwater....except at full boost.
The turbo just quieted the motor so much.
Dan
67 charger
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: court9155] #975515
04/19/11 09:25 PM
04/19/11 09:25 PM
Central NC
gch Offline
gch  Offline
Central NC
I say get the source/edelbrock heads,have the valve job checked,and put springs to match the cam.
You havent mentioned the gears.That would factor heavily into the cam on a 383 build.Be pretty easy to get 425hp out of this with some good heads and still be smooth down low.
Even 400hp will be sweet.Build for torque,put some 3.23's in it and cruise.Will be a blast from a roll on the street.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: gch] #975516
04/19/11 10:00 PM
04/19/11 10:00 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Biggest factors ARE the cam/converter/compression and gears. The carb size is determined by a REALISTIC max rpm dictated by the combination.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975517
04/19/11 10:27 PM
04/19/11 10:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
http://www.440source.com/strokerkits.htm
scroll down to the 383 kits
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975518
04/20/11 12:45 PM
04/20/11 12:45 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
RUMBLON
John, I thinks thats the way I am going to go.However I thought my engine builder said he would have to change more than that.
The motor is only 10:5 compression.500 stroker.I have lost the cam sheet and receipts from440 source but its one of their stroker kits. And then my guy bought and did the eddy heads with aluminum rockers.
so you think its just a cam replacement and intake? would the aluminum rockers live long on the road? How about the push rods? I thought he said he had to change those or maybe it was just check them.
what cam would you guys recommend and manifold if this is the case and what HP do you think I would be at?
RUMBLON
Page 2 of 3 1 2 3
