Page 1 of 3 1 2 3
Need ideas for a 450HP build on my 383/ street motor? #975479
04/18/11 03:15 AM
04/18/11 03:15 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
OK, I am going to build my original 383 for this 63 Polara vert. However I want to pep it up a bit. I would like to get 450 HP and make it very streetable. Its its original 63 383. I dont know the heads of this era and I am open to buying a set of Eddy heads or what ever it takes to make it right.
The car will have its power steering, power brakes and after market air.
I had planned on using my 500 (650 HP) stroker for this project but my engine builder says he thinks its not right for the street.Solid lifter motor and would not last long when cruising in it.
So I need to build a nice running 383. what have you folks done and what suggestions do you have on what to use from this engine and what to replace or upgrade.
RUMBLON
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975480
04/18/11 03:17 AM
04/18/11 03:17 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
ORIGINAL ENGINE
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975481
04/18/11 03:18 AM
04/18/11 03:18 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
ONE MORE
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975482
04/18/11 07:47 AM
04/18/11 07:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
stock stroke, high compression, good heads, and a big cam would get you there I'd think.
or you can cheat, drop a 440 stroke crank in there from your choice of stroker sources, (aftermarket that's already made for the 383/400 mains) and turn the 383 into a 426, 431, or 438 depending on how much you have to bore the cylinders. That, combined with compression, head flow, and cam, will get you 450-500 hp that is VERY streetable.
my 383 stroker was making over 500 lbs of torque at 3,000 rpm where the dyno started measuring, and it stayed at a nice flat 500 lbs through the RPM range, peaking at 535 at 3800, and made a peak of 505 hp. that's with the above combo--440 stroke, flat top pistons, eddy heads, comp's xe-275-hl hydraulic cam.
**Photobucket sucks**
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975483
04/18/11 09:49 AM
04/18/11 09:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd say the cheapest would be to get a set of 440 source heads and storker kit and roll. Well unless you can find a deal on a complete Big Block already done.
Coming soon!!!!
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: Mr.Yuck] #975484
04/18/11 12:33 PM
04/18/11 12:33 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'd suggest a smaller stroker (438) with a stable CH piston, Stealth/Eddy heads, Eddy RPM, higher compression at your altitude, a nice hyd. cam, 1-3/4" headers, 2-1/2 exhaust. Should have no problem hitting 450 HP. It's also do-able with stock displacement but you'd have to get a bit more aggressive with the choices.
I made about 560 HP (and left about 20-30 HP on the table) with my 383/451, but it's not a cruising combo.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: 70Cuda383] #975485
04/18/11 01:27 PM
04/18/11 01:27 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a street driver I'd follow this recipie...the smallish cam should have good streetability, tons of torque and good power to about 5500 RPM.
if you're buying a new crank, I'd go past the 3.75" stroke and into a 4.15" crank, if you can find a shelf piston for a 4.28" bore/4.15" stroke combo. would yield 478 cubes and probably 520-560 lb ft of torque, with about 500 HP
2017 Grand Cherokee Overland
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: patrick] #975486
04/18/11 01:29 PM
04/18/11 01:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There isn't a shelf piston for that stroke , 3.75 , 3.9 and 4.25 all use the same CH piston , 1.32 . Diamond has a piston for a 3.75 stroke using the std length B rod for a taller piston .
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975487
04/18/11 01:37 PM
04/18/11 01:37 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Call Jim Laroy in Challis Id and have him build it for you, He's a great Mopar guy.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975488
04/18/11 04:10 PM
04/18/11 04:10 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Good call. Didn't know about those pistons. By my math that gives a 1.75"-ish CH. Not too tall; not too short. A cleaned up stock forged crank and maybe some new CCJ rods and you're into it pretty reasonably.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: 64Post] #975489
04/18/11 04:21 PM
04/18/11 04:21 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Dare to be rare.
Stock stroke 383s can and do make power. Source heads just make it easier and cheaper.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: JohnRR] #975490
04/18/11 04:34 PM
04/18/11 04:34 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
then I'd probably go 3.9 or 4.25 for a street car, and keep the powerband in the idle-5500 RPM range.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: patrick] #975491
04/18/11 05:03 PM
04/18/11 05:03 PM
Hightstown, NJ
njdevil2 Offline
njdevil2  Offline
Hightstown, NJ
Not to hijack this thread, but I plan to do something simaler, I'm trying to do 400 HP with a stock '70 roadrunner 383. It already has a 440 cam and 9.5:1 compression. It has the CH4B (I think) Aluminum Edelbrock intake from 1969. I have aquired a Holley 670 Street Avenger. I'm pretty sure that the 1.75" headers are the thing I need for the exhaust with 2.5" exhaust pipes. Does this sound like the right recipe? I'm trying not to mod the internals, it's a recent rebuild. Any suggestions on the header brand?
1970 road runner Convertible
1 of 179
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: njdevil2] #975492
04/18/11 08:33 PM
04/18/11 08:33 PM
Tehachapi CA
MRBELV2 Offline
MRBELV2  Offline
Tehachapi CA
How about the 528 solid cam in a zero deck (approx 10-1)engine with the eddies, RPM, and your choice of 4bbl carb? May be close to your HP goal.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: MRBELV2] #975493
04/18/11 08:39 PM
04/18/11 08:39 PM
ohio
2
2264PLY Offline
2264PLY  Offline
ohio
Does it have to be 383? A 440 would get you there so much easier.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: njdevil2] #975494
04/18/11 08:44 PM
04/18/11 08:44 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I would use (and do) the 1 7/8 hookers. The cam is small if its the chrysler cam. there were two... small and smaller.
But if you already have everything, they will work well as a mild combo. You can easily change cam/carb/intake down the road.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RemCharger] #975495
04/18/11 08:48 PM
04/18/11 08:48 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Dare to be rare.
Good advice.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: njdevil2] #975496
04/18/11 08:53 PM
04/18/11 08:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Intake would be the DP4B , CH4b is the 440 intake .
Who rebuilt it, what pistons are in it? Many people THINK they are building 9.5 or 10.0 compression 383 with the currently available pistons but unless they zero deck the block and cut the heads down to at least 82ish cc then it's not really that high ... or use the KB 400 DOME piston. The stock 68/69 383 HP has 9.3 compression at best, how anyone thinks they are building a 9.5 or 10.0 engine with a piston that is .024 or more in the hole without zero decking AND use a composite head gasket that almost twice as thick ass the original is beyond me.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: RUMBLON] #975497
04/18/11 11:32 PM
04/18/11 11:32 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
The term "very streetable" means different things to different people. If it means smooth idle in neutral (14 -15" vacuum) and in gear with a stock torque convertor, hydraulic cam and pump gas, it will be difficult getting to an honest 450 hp IMO. In my experiance you can get to 1.0 to maybe 1.1 hp/cu.in. under those conditions. Go to 440 cu.in, it gets a lot easier.
Re: Need ideas for a 450HP build on my 383/ street motor? [Re: 2264PLY] #975498
04/19/11 02:13 AM
04/19/11 02:13 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I am currently out of 440s, except the finished solid lifter done 500 stroker I have sitting in the shop, that was originally for a drag car that I wont be using now.
My engine builder believes that its best to use that motor for what it was intended to be for or sell it or trade it for a done motor for this car.
So I was hoping to build the 383 that I have. But This is why I am posting the thread. To weigh out my options.
RUMBLON
Page 1 of 3 1 2 3
