VALVE TRAIN CLATTER, 5.9 1997 RAM
#975369
04/17/11 11:34 PM
04/17/11 11:34 PM
Posts: 1,937 Walmart parking lot
yorker
Drugs are bad
Drugs are bad
Walmart parking lot
My 97 Ram, 5.9 with only 142,000 original miles on it has started to give off what sounds like valve clatter or something else in the valve train.
I hear it very faintly when when taking off from a stop, generally just before it shifts into second gear at around 1,900 RPM. Seems like it is getting worse and sometimes a little louder.
I can also hear it sometimes when going 65 mph with the overdrive shut off. I think I had read these motors had weak valve springs or something like that. My oil pressure is normal. I have owned the truck about 5 years and have had it at WOT many times.
Question I have is, how fast will this condition deteriorate? The truck is very clean, but I am not up to repairing this myself, and probably not worth paying to have it done.
I only drive the truck about 2,000 miles a year so maybe I can just tuff it out. Guess this motor is not Ram tough.
Anyone deal with an issue like this with the 5.9?
Thanks in advance.
Re: VALVE TRAIN CLATTER, 5.9 1997 RAM
[Re: 71yelladustr]
#975371
04/18/11 08:14 AM
04/18/11 08:14 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Have someone check the timing for you at idle and around 2000 rpm. See if it jumps up too high at any certain rpm. The valve springs are beehive springs and are pretty durable, especially with a stock hyd roller.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
