Have someone check the timing for you at idle and around 2000 rpm. See if it jumps up too high at any certain rpm. The valve springs are beehive springs and are pretty durable, especially with a stock hyd roller.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
