What ballast resister to use? #975114
04/17/11 07:58 PM
04/17/11 07:58 PM
Illinois USA
justnuts40 Offline OP
Illinois USA
Hi, Looking for some suggestions on what ballast resister to use on my street rod. Its a 360 with a Mopar Performance electronic ignition.
Any help?
Thanks for the post, Tony
etony58@gmail.com
Re: What ballast resister to use? [Re: justnuts40] #975115
04/17/11 08:06 PM
04/17/11 08:06 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
go to parts store and ask for 1 for a 74 360 cuda.
Re: What ballast resister to use? [Re: justnuts40] #975116
04/17/11 08:08 PM
04/17/11 08:08 PM
pretty much depends on what coil you plan to use. OE coils iirc have either .5 or 1.5 ohms on the pri side. the ballast supplied w the orange/chrome MP kits is nominal 1.25 ohms but not sure what coil that kit is designed for
Re: What ballast resister to use? [Re: RapidRobert] #975117
04/17/11 08:34 PM
04/17/11 08:34 PM
Illinois USA
Illinois USA
Thanks for the in put. The coil I got is new, chrome cased one that I got from a swap meet. There is nothing on it except (+) and (-)?
Re: What ballast resister to use? [Re: justnuts40] #975118
04/17/11 09:25 PM
04/17/11 09:25 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
The cool guys use .25 ohm (for a Blaster 2 coil for instance). The sinners (and losers) use 1 ohm or above. Which produces more heat and takes longer to recover ? Why, the resistors they sell you at the parts store !
