truck bolt pattern swap #97504
07/31/08 03:24 AM
07/31/08 03:24 AM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
I have a '85 Ram 1500 truck w/ the 5x5.5 bolt pattern. I want to run 5x4.5 pattern wheels WITHOUT adapters. Are there any rotors & axles I can swap to or any accessories I can use to do this? Any help would be appreciated.
Re: truck bolt pattern swap [Re: 440child] #97505
07/31/08 04:12 AM
07/31/08 04:12 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yep, throw a set of 81 to 84 rotors at the front, and swap your rear axles for a set from the same years. Of course, make sure you use 9.25 or 8.25 axles as appropriate.
Mike
Re: truck bolt pattern swap [Re: 1E2C] #97506
07/31/08 08:23 AM
07/31/08 08:23 AM
scratchnfotraction Offline
76 new yoke rotors are the same also
swap the axles and the drums,use same axle size from a doner axle
good time to upgrade to a larger brakes on the rear also
