Re: freshly welded fuel sump pics...pump questions
[Re: turner]
#974481
04/16/11 06:46 PM
04/16/11 06:46 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
nice work!! buy a Holley HP150, their great pumps and a little quieter than the old blue's and they still don't need a return
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: Crizila]
#974483
04/16/11 08:35 PM
04/16/11 08:35 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Nice job. I had to MIG mine , but it worked O.K. I was a little gun shy about burning through , but either I got lucky or am getting better at welding. ![](/ubbthreads/images/graemlins/laugh2.gif) I went with holes in the tank too..........last sump I used , I had it done and the guy cut a big rectangle out where the sump went. But the thought of a bit of control over sloshing was a no brainer. I used a BG 220 HR for a similar output small block , but those pumps are headed the way of the brontosaurus. I wanted something that wouldn't balk at continuous use , since the car will see a fair bit of street miles. With 1/2" or #8 line , you should be O.K. with a Holley Black. I tend to go for overkill , but a lot of guys use them in some pretty quick cars.
[Re: Keith Black®]
#974487
04/17/11 01:46 AM
04/17/11 01:46 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
running 2 x A1000 Aeromotive's staged. suspended into tank from top access plate. EFI on my ride:
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Crizila]
#974489
04/17/11 07:01 AM
04/17/11 07:01 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I run mine dead headed. Good pump!
Same here.
