can we go over my 509 HYD combo? #974276
04/16/11 11:32 AM
04/16/11 11:32 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
its very inspiring to read about mild combos yall have had success with.. certainly with the 509 hyd cam. my budget is probably not going to allow adjustable valvetrain so if im stuck with stock type stuff the 509 looks like my answer. ive actually called james at UD and he has a nice 247 533 lobe that would work good too. heres the combo what do you think? thanks
1974 dodge dart sport 3550lbs with me
440 2295's ly rods arp bolts cast crank (approx 11.0 CR)
fully ported stealth alum heads 320 cfm
torker2 intake ported to match heads 850 holley
2 inch pro parts 3 inch duals with x pipe
built 727 with 4k "race" tci converter (will restall to ??? it wants)
ford 8.8 31 spline 3.73s 26 inch slicks. 6k shift point?
id be thrilled to see some lower 7's in the 1/8th
Re: can we go over my 509 HYD combo? [Re: shoebox] #974277
04/16/11 11:46 AM
04/16/11 11:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks good. Probably like a little more gear but that should work pretty well. You really don't need the fully ported heads, If you want to save money that's a good palce to start. Not sure how strong those factory 8.8's are. I guess you'll find out. Looks like an easy low 12 combo, not sure what that would be in the 1/8th
Coming soon!!!!
Re: can we go over my 509 HYD combo? [Re: Mr.Yuck] #974278
04/16/11 11:52 AM
04/16/11 11:52 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
my head porter wants to go through them to get the lower lift numbers up and to see what these casting really flow in the real world!
Re: can we go over my 509 HYD combo? [Re: shoebox] #974279
04/16/11 11:53 AM
04/16/11 11:53 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I went 11.52 with almost the same combo in a 383 Demon.Used 906 heads and more gear/larger tire,750 Holley.I'd agree you might need more gearing.But should run 7.20 easily.
Nautilus Racing-
Re: can we go over my 509 HYD combo? [Re: Chris2581] #974280
04/16/11 11:55 AM
04/16/11 11:55 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
id be thrilled with 7.20's im willing to do whatever gear and stall the combo wants. i wonder how loose on the stall you could go with the 509?
74 dart sport 440 www.Csucarbs.com
Re: can we go over my 509 HYD combo? [Re: shoebox] #974281
04/16/11 12:14 PM
04/16/11 12:14 PM
Get-X Offline
Get-X  Offline
I'd try and use a good 9.5" vert around 4400. PTC sells one cheap for what you get. That combo should run low 7's all day long.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: can we go over my 509 HYD combo? [Re: Get-X] #974282
04/16/11 12:30 PM
04/16/11 12:30 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Awesome ill check it out
Re: can we go over my 509 HYD combo? [Re: shoebox] #974283
04/16/11 01:04 PM
04/16/11 01:04 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Be sure to invest in some c-clip eliminators My mustang that i had(yeah I know ) Popped a c clip on the line with a mild 306 and drag radials. Luckily I had already pushed the clutch back in because it felt like it was slipping or it could have been nasty.
Re: can we go over my 509 HYD combo? [Re: SLOW67] #974284
04/16/11 01:14 PM
04/16/11 01:14 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Axles are aftermarket
Re: can we go over my 509 HYD combo? [Re: shoebox] #974285
04/16/11 01:24 PM
04/16/11 01:24 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Do they still have c-clips though? My car too had moser axles but still had the clips. After that experience I bought the eliminators...
Re: can we go over my 509 HYD combo? [Re: SLOW67] #974286
04/16/11 01:48 PM
04/16/11 01:48 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
These are moser w clips. Never had an issue knock
On wood lol
Re: can we go over my 509 HYD combo? [Re: shoebox] #974287
04/16/11 01:55 PM
04/16/11 01:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Those 8.8's are dang strong. The combo sounds good and Id be surprised if it didnt run that or better.
I ran a 493 with Box stock eddy heads with a 509hyd and it ran strong for sure.
Re: can we go over my 509 HYD combo? [Re: shoebox] #974288
04/16/11 09:51 PM
04/16/11 09:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The gearing is fine, with those 3.73 gears and 26" slicks, you have slightly more gearing then a 4.56/32" slick combo.
Your stalls a little low, 4500 would be better. The Torker II will hurt the launch @ 3550# with a 4000 rpm vert costing you some ET.
Its got the potential to run 7.20,s IMO Your combo is similer to mine but 600# heavier. Ive run mid 10.40,s Add a 600# ballast ET penalty to my car and it would be running 7.20,s IMO So you should be able to run near that too.IMO
Re: can we go over my 509 HYD combo? [Re: Sport440] #974289
04/17/11 01:16 AM
04/17/11 01:16 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Hopefully imight be lighter than i think
Re: can we go over my 509 HYD combo? [Re: shoebox] #974290
04/17/11 05:01 AM
04/17/11 05:01 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think easy low 11s/7.20s even with a 509 cam. I wouldn't worry about gearing its not bad with a 26" tire. Your stall will work fine too. The 509 is not optimal for this engine but you probably already know that. If you must run a hydraulic id find something with similar duration and more lift. Id recommend you check out the comp xe295hl. It has .561 lift and is 251@050.
Re: can we go over my 509 HYD combo? [Re: viperblue72] #974291
04/17/11 11:25 AM
04/17/11 11:25 AM
Central NC
gch Online content
gch  Online Content
Central NC
With a 26" tall that is'nt that wide I would be focusing on getting it to hook.60ft time will make or break ya.
Re: can we go over my 509 HYD combo? [Re: gch] #974292
04/17/11 11:32 AM
04/17/11 11:32 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I know 60 60 60 60 ft its all about getting moving!
Re: can we go over my 509 HYD combo? [Re: shoebox] #974293
04/17/11 02:00 PM
04/17/11 02:00 PM
There is no way I would NOT put adjustable rockers on this motor You've spent a ton of money already getting mostly good parts, don't stop now Wait a little longer to buy a decent set of adjustable rockers and pushrods to match, the stock stamp steel rockers are not precise at all on the rocker ratio To be truthful a lot of the aftermarket rockers are not that great either but there way better than the stock stuff
Re: can we go over my 509 HYD combo? [Re: Cab_Burge] #974294
04/17/11 02:03 PM
04/17/11 02:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
many folks have run 509 cams w/ non-adjustable valve train. It's hydrolic. I ran a bad butt 383 w/ a 509 and heavy duty rockers, shafts an push rods. So have many of my friends. I don't think it will hurt at all but he would pick up a few HP with roller adjustables.
Re: can we go over my 509 HYD combo? [Re: Mr.Yuck] #974295
04/17/11 02:05 PM
04/17/11 02:05 PM
tboomer Online work
tboomer  Online Work
I agree with Cab...At least put some Isky or Crane iron rockers on...For peace of mind..
