Using in tank EFI fuel pumps on car with carburetors. #974236
04/16/11 10:52 AM
04/16/11 10:52 AM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
I have seen EFI cars converted to carburetors and I believe the origional EFI fuel pump was used. What did they use to convert the high EFI fuel pressure to something that is reasonable for a carburetor?
Since the above is possible and has been done it would seem the reverse situation could be done. And that is use an electric EFI fuel pump in a car that was origionally built with a carburetor. Most of the EFI fuel pumps seem to have high delivery and most seem small enough to slip inside the older cars fuel tanks. All you would have to do is use the fuel pickup unit to support the fuel pump and use a regulator to reduce the pressure to somethin reasonable.
Has anyone here successfully done this?
Thank,
Roger
Re: Using in tank EFI fuel pumps on car with carburetors. [Re: rjones] #974237
04/16/11 11:05 AM
04/16/11 11:05 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I use one of these and have gone back and forth between efi and annular carb on my one vehicle many times. Comes with two springs, and you just swap springs. My A1000 pump is in the tank...Just remember with a carb, your returning more fuel and you need a healthy size return line...
http://www.jegs.com/i/Aeromotive/027/13301/10002/-1
Re: Using in tank EFI fuel pumps on car with carburetors. [Re: Dragula] #974238
04/16/11 06:19 PM
04/16/11 06:19 PM
QLD Australia
Keith Black® Offline
QLD Australia
Darren Beale
Keith Black Racing Engines®
