Re: Disc brake rotor help needed for 70 RR
[Re: BDW]
#973806
04/16/11 02:20 AM
04/16/11 02:20 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
Do yourself a favor and upgrade to the later 1 piece rotors. Contact Dr Diff and use his adapter sleeve.
http://cgi.ebay.com/ebaymotors/70-72-Mop...emZ170621126454
Thats a good idea. I bought from Cass before. I didn't realize he was a disc brake guru too.
I think I have to start by identifying which steering knuckle I have. Hopefully he can help me ID mine.
Since my existing setup has a two piece rotor, does that mean I definitely have the 70-72 B/E body steering knuckle?
[Re: Finoke]
#973809
04/16/11 11:25 PM
04/16/11 11:25 PM
Posts: 801 central CT
cudazappa
central CT
it is as easy as that. I'm running his spindle sleeve on my 71 challenger. I also ended up upgrading to the bigger Cordoba rotors (11.75") and used the pin type adapter so I didn't even need to disconnect my calipers!
1971 Challenger
[Re: cudazappa]
#973810
04/21/11 08:30 AM
04/21/11 08:30 AM
Finoke
Horsham, Pa.
Good to know, I ordered from DR DIFF yesterday.
Thanks!
[Re: Finoke]
#973816
04/25/11 02:00 PM
04/25/11 02:00 PM
Posts: 5,268 NY
70440+6bbl
NY
[Re: 70440+6bbl]
#973817
04/25/11 03:45 PM
04/25/11 03:45 PM
Finoke
Horsham, Pa.
Is your tag coded B51?
Yes it is. Is B51 the code for power brakes or power disc brakes?
I would have thought to see B41 if my car was originally disc brake. I don't see a separate disc brake code on my tag. Just B51.
[Re: 1_WILD_RT]
#973818
04/25/11 03:46 PM
04/25/11 03:46 PM
Finoke
Horsham, Pa.
The dust shield with the shorter lip is from a 73 & up vehicle.. In order to keep my stuff looking like 70 vintage I actually use the early shield but I cut the raised area off....
I thought of doing that too. But I happened to have these other shields in my stash
[Re: Finoke]
#973819
04/25/11 05:01 PM
04/25/11 05:01 PM
Posts: 5,268 NY
70440+6bbl
NY
I don't think the G-plant stamped the tags with B41. My buddies all original documented '70 RR ragtop just has the B51 stamping and is a disc brake car.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
