New motor with high oil pressure... #973765
04/15/11 01:45 PM
04/15/11 01:45 PM
Roseau, MN
1976 Aspen Offline OP
Roseau, MN
I put my new mill on the dyno and at idle I have 75 psi and at WOT it goes to 100 psi. I'm running 15W-40 Rotella T in it so I'm thinking about switching to a 5W-30 or something to get it down. I like the Rotella T but they don't make it in a 5W-30 or maybe I should try a synthetic??? It's a 700 HP small block that spins to 7200 rpm's and used on the strip only. It's in the car already and I don't wanna pull it out to mes with the pressure spring either... Any suggestions are greatly appreciated!!!
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973766
04/15/11 01:50 PM
04/15/11 01:50 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Rotella makes a straight 30 and 10w30 oil. Last season I ran the straight 30 and got 80 psi cold and 30 hot at idle. I found 10w30 Rotella this year and just changed my oil with that last week. I am still getting 80 psi cold but hopefully the 10w will help the oil warm up faster. I have also decided to use a bottle of STP with my oil season because I have heard that the zinc levels have also dropped in the Rotella products.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973767
04/15/11 02:09 PM
04/15/11 02:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You only have 1 choice left.... thinner oil
Re: New motor with high oil pressure... [Re: MR_P_BODY] #973768
04/15/11 02:15 PM
04/15/11 02:15 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
JUSTA' thought ....
I remember an article in National Dragster some years back written by WJ .... He ran ZERO weight oil at 50 psi max.
Running the oil pump UP as high as you do costs HOESpower !
Re: New motor with high oil pressure... [Re: dOc !] #973769
04/15/11 02:44 PM
04/15/11 02:44 PM
gregsdart Offline
gregsdart  Offline
Don't forget that what keeps the bearings happy is the "wedge" of oil that separates the journal from the bearing. Too light of an oil mixed with too big of a clearance and you have a rod stuck through the block. Not a good deal. For us do it yourselfers, 20w50 and larger clearances make the most sense. pull the pan and set the pump properly, or run the risk of bearing failure. To ease the process, get a priming rod so you can spin the pump for a test with the pan held with a couple of bolts, then you can put it together the rest of the way when you are happy with the pressure output. A good 3/8 drill will give you full pressure readings.
Re: New motor with high oil pressure... [Re: gregsdart] #973770
04/15/11 03:10 PM
04/15/11 03:10 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
I and a few others had the same problem last spring when I used a new Melling pump on my SB. 70 at idle and over 100 revving. I switched to 5W20 and it's fine now. Cold idle is 60, hot idle 45, and at speed it's around 70.
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973771
04/15/11 03:33 PM
04/15/11 03:33 PM
Az
Crizila Offline
Crizila  Offline
Az
I have the same issue with my 408. After break-in, I went with a full synthetic ( 10-30 Royal Purple ) and droped the pressure by about 15 psi accross the board. Pressure is still a little higher than I would like and I'm sure it's costing my some HP, but I have been running it that way for 3 years now with no problems. Remember, after you get some runs on it the pressure will come down a bit also. IMO, people run too high a viscosity oil in general. Todays lubes are a bunch better than years ago.
Fastest 300
Re: New motor with high oil pressure... [Re: Crizila] #973772
04/15/11 04:51 PM
04/15/11 04:51 PM
Locomotion Offline
Locomotion  Offline
I've gotten lower oil pressure after switching from higher viscosity break-in oil to thinner race oils. (old 30 or 40w race oils to 5w-20 Amsoil Dominator synthetic) and it's definitely faster, from idle to 1/4 mile. But don't bank on the diesel oils having a lot of zinc, especially if you are running flat tappets. They've been reducing them also and you have to keep checking reliable sources to keep up. But some do advertise extra zinc, which doesn't hurt a race motor either way.
Amsoil high zinc synthetics
Re: New motor with high oil pressure... [Re: Locomotion] #973773
04/15/11 04:58 PM
04/15/11 04:58 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Diesel oils have low zinc levels because the trucks now have cats on them just like a car. My last sb race motor a ran 10/30 brad penn and it still had 70 psi cold.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: New motor with high oil pressure... [Re: 1967dartgt] #973774
04/15/11 05:08 PM
04/15/11 05:08 PM
Guitar Jones Online laugh2
Man you guys need to keep up with the times. I'm running 5W-20 synthetic in my motor. That 20w and 50 weight crap is old, old news.
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973775
04/15/11 11:12 PM
04/15/11 11:12 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
mine did the same thing vr1 10 30 now its a little high for about a min till motor warms up
Re: New motor with high oil pressure... [Re: fishy340] #973776
04/16/11 10:22 AM
04/16/11 10:22 AM
Roseau, MN
Roseau, MN
I think I'm going to try Mobil 1 10W-30 Full Synthetic and see what happens. Thanks for all the info!!!
Re: New motor with high oil pressure... [Re: bigsbigelow] #973777
04/16/11 01:09 PM
04/16/11 01:09 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I run rotella in everything including my daily driver but In all my flat tappet stuff I still pour in a bottle of GM EOS
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973778
04/16/11 01:28 PM
04/16/11 01:28 PM
See if you can get some 5W20 Mobil 1 don't rev it past 2000 RPM for several minutes and see what the pressure does as it warms up some I run 5W20 valvoline non synthetic in all of my motors, BB and Hemi, race or street. I set all of my clearances up real loose and I set the bypass spring to have 10 lbs of pressure for each 1000 RPM, IE 70 lbs at 7000 RPM with hot oil. My 518 pump gas street motor has 65 lbs cold at or above 1000 RPM and 18 to 22 lbs at 800 rpm with 180 F degree oil, 45 lbs at or above 1200 RPM and 65 lbs at 6500 RPM
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973779
04/16/11 09:41 PM
04/16/11 09:41 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
When I built my 414 with a new Melling pump I had the same issue only much more drastic. The needle on the gage, at WOT, would actually go almost all the way back around to zero! I thought that the gage must have taken a crap so I tried another, but same thing. Switched from the Mobil 1 15/50 to the real thin Royal purple stuff just to see what it would do, and it lost about 20 psi across the board, but still WAY to high. Took the pump out and had my engine guy check it out, even though he had blueprinted, and deburred everything and checked the pressures on his oil pump dyno. Again, it checked fine, all he did was took out the piston and spring, check piston travel, and then lightly hone the piston and bore. I put it back in the motor and again WAY high press? ARG!! So I then just got another Melling pump, had my guy "go over" it and put it in and it was perfect, about 30 psi at idle hot, and 75 at WOT. Why was the other so high? Dunno, but maybe ya just need to try another pump. With the new pump in ET was just over a tenth quicker in the 1/4. Good luck.
Re: New motor with high oil pressure... [Re: StrokerPost] #973780
04/16/11 09:50 PM
04/16/11 09:50 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Rotella makes a 5-40w synthetic diesel oil!
Re: New motor with high oil pressure... [Re: 1976 Aspen] #973781
04/16/11 11:37 PM
04/16/11 11:37 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
Ryan,
What are your main and rod clearances? If your a little big on the clearances run a straight weight. I am just in the process of putting my back together and put a oil pan heater and two block heaters in. The engine with most likely be 150 before I fire it LOL!
