Choke well, crossover, and headers #973646
04/15/11 11:50 AM
04/15/11 11:50 AM
South Coast of Oregon
dweller Offline OP
dweller  Offline OP
I'm using a termoquad on a Performer manifold and headers on my 440. I've searched and done alot of reading on the subject, but its not clear whether the exhaust passage under the choke well will warm up without the stock exhaust manifold valve to force exhaust through the passage. Will it warm up enough to use the stock spring-style choke?
Re: Choke well, crossover, and headers [Re: dweller] #973647
04/15/11 11:55 AM
04/15/11 11:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
It will take longer to heat up, so I would try to get the choke that is electrically supplemented too, like many of the later ones were.
Re: Choke well, crossover, and headers [Re: buildanother] #973648
04/15/11 12:03 PM
04/15/11 12:03 PM
N.J. north west
1972challenger Offline
N.J. north west
I would block off the heat cross over. Usually if your idle circuit is adjusted properly the engine will run fine with out a choke. The engine will run better at higher temperatures with the heat cross over blocked off. If you do a lot of cold weather driving use a manual choke and hide the knob under the dash.
Re: Choke well, crossover, and headers [Re: dweller] #973649
04/15/11 01:33 PM
04/15/11 01:33 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
What is a termoquad ?
YOU are cool ...with an alum intake. It warms up muchO bester and way quicker than an iron one.
Re: Choke well, crossover, and headers [Re: dOoC] #973650
04/16/11 02:39 PM
04/16/11 02:39 PM
dweller Offline OP
dweller  Offline OP
Will the intake warm up sufficiently to pull off the choke if the crossover is blocked? Or should I leave the crossover open?
Re: Choke well, crossover, and headers [Re: dweller] #973651
04/16/11 10:28 PM
04/16/11 10:28 PM
Shoreline, Washington
72roadrunnergtx Offline
Have look at this thread , may answer some of your questions.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Choke well, crossover, and headers [Re: dweller] #973652
04/16/11 10:31 PM
04/16/11 10:31 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I would leave it OPEN. Much better street-manners and MPG.
Re: Choke well, crossover, and headers [Re: 72roadrunnergtx] #973653
04/17/11 01:07 AM
04/17/11 01:07 AM
dweller Offline OP
dweller  Offline OP
Thanks, good reading...
