99 Ram trans issues
#973610
04/15/11 09:04 AM
04/15/11 09:04 AM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Hey guys, I have a 99 Ram SLT 2wd 5.2L with 46RE Trans. About two weeks ago I noticed the 2-3 shift delayed, all other shifts were normal. I did the following;
1. Drop pan, clean, small amount of clutch material on magnet, like toothpaste. 2. Adjust front and rear bands per service manual 3. Install new filter and ATF+4 plus 1 pint of Seafoam trans tune 4. Re-adjust the Throttle valve cable
All this week the trans shifted much better even when warm, but yesterday after a bit of stop and go in town it started late shifts in 1-2 and 2-3. This morning on way to work (5 miles)it shifted fine. Its not slipping, I hold fixed throttle position and engines revs up 2500rpm and holds there until I lift off and then it shifts.
So, in a previous search here I found;
"just bought a 96 ram xtended cab long box with 156 000 miles on it. Truck runs great except for one issue with the tranny (46RE). As you are accelerating up to speed it REALLY hangs onto gears. 1st to 2nd isn't so bad, 2nd to 3rd is bad, 3rd to 4th not so bad. It's to the point that I have to pretty much let off the gas to get it to shift. Also, when you floor it at 60 mph, it shift right down to 1st, pegging the tach to 6000 rpm, not good (only did that once) . The tranny doesn't slip, make noises, nothing. The fluid is a nice color, no stink, but it is very low, barely on the dipstick, could this be the issue? Or could it be the TV cable needing adjsutment? I'm not up on transmissions, but is there a speed sensor, since this is an electronic transmission? **I did some more digging around on the net and the symptoms that my truck was exhibiting pointed to governor pressure solenoid, like Big Terry (and Rick Ehrenberg from MA)suggested. Further digging also revealed that it was probably a good idea to replace the pressure transducer on the governor, and also the solenoid that controls the TC lock up and overdrive engagement, as my truck would spontaneously kick the TC out from time to time and would take forever on cold mornings to engage OD. So I bit the bullet and ordered all 3 brand new from Dodge, as well as a filter (not cheap). I replaced all 3 and the filter, took about 4 hours, and the tranny now shifts perfectly. So, if you have the symptoms that I described, replace all the solenoids first before you remove it for a rebuild. If that doesn't fix it well it's probably time for a rebuild and you already have all the solenoids that you would have to buy anyway for the rebuild.**
Does anyone think this should be my next step???
Thanks, Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
Re: 99 Ram trans issues
[Re: gtx6970]
#973612
04/15/11 09:38 AM
04/15/11 09:38 AM
shaker340
Eastern Ontario
The truck has 110,000 mile on it now. I bought the truck at 75,000 miles and did a filter and oil change then. Previous to that is unknown.
Mike
[Re: gtx6970]
#973614
04/15/11 10:13 AM
04/15/11 10:13 AM
shaker340
Eastern Ontario
So its probably the front drum piston seal? I had this problem with my 727 in the Cuda, but I also had a lazy reverse.
Does the 46RE work the same way? My reverse engagement is normal when cold, need to see when its warm.
Thanks so far, if anyone else can add suggestions I appreciate it.
Mike
[Re: shaker340]
#973615
04/15/11 11:35 AM
04/15/11 11:35 AM
Posts: 21,499 It's a dry heat
gtx6970
It's a dry heat
That would be my guess. But yes ,,,All a 46RE is nothing more than a 727 with an OD on the end and an electronic computer controlled governor
[Re: gtx6970]
#973616
04/15/11 11:58 AM
04/15/11 11:58 AM
shaker340
Eastern Ontario
GTX6970 Thanks for your input. It would be cheaper for me to get this trans rebuilt than to buy another vehicle.
Mike
[Re: shaker340]
#973617
04/15/11 12:07 PM
04/15/11 12:07 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Mike
Front drum piston seal is a known problem, Chrysler or the supplier did a big run of drums with the inner seal groove cut a little too deep , it's ok when they are new but as the seal ages it will eventually shrink into the bore some and it will start to do what you are describing , as it gets worse you'll get an RPM flare on the 2-3 shift and when it's real bad reverse will SLAM into gear like you rev it in neutral and slammed it into gear . The Transtar gasket kits now come with 2 front clutch inner pistons seals one normal, one wider , the wider makes it a little harder to get the piston in.
Rebuilding the 46RE front section is basically the same as doing a 727, the OD is scary when you have to replace the OD Direct clutches.
[Re: JohnRR]
#973618
04/15/11 12:17 PM
04/15/11 12:17 PM
gtx6970
It's a dry heat
Typically if you lift your foot off the accelerator slightly and it upshifts, you have an internal seal/piston/drum problem.
IF ( key word ) it's the ft piston seal, changing the fluid might help. But it may take a week or so to see any improvements. I've had several over the years that changing the fluid has helped . New fluid tends to soften the seals slightly and allow them to seal better,,,,,,for a while.
[Re: gtx6970]
#973619
04/15/11 12:31 PM
04/15/11 12:31 PM
shaker340
Eastern Ontario
Yes I replaced the fluids and noticed an improvement, but it still has upshift delay once warmed up and does not do it all the time. I think I'll continue to drive it daily and see if it gets worse over time. If it does, I should get a complete rebuild??.
Thanks JohnRR for chiming in, I knew you would. You have helped in the past with the 727 in my Cuda.
Mike
[Re: shaker340]
#973621
04/15/11 03:06 PM
04/15/11 03:06 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Mike
They also have converter issues, I bought my 99 with a rebuilt tranny, had the receipt for the job, After a few days i realized why the guy sold it , IMO those trannys are a total POS, I'll NEVER buy another dodge truck of this era, sold that sucker off & couldn't be happier (freakin gas hog too), the only real good thing about that truck was the engine (360) .
Just make sure if you have it rebuilt, make damn sure they replace those noids & the converter with top quality units, otherwise you'll be in the same boat in no time i'll garauntee you that, Exspect to pay around 1800.00 minimum for the job, If less it won't be a good quality rebuild, good luck
[Re: JohnRR]
#973622
04/15/11 05:35 PM
04/15/11 05:35 PM
Posts: 4,076 Mo.
racerx
Mo.
You have to pull it out and open it up to replace that seal , might as well go thru it while it's out .
So john r this OD transmission hard to rebuild? I'v got a few 727 under my belt just was wondering about the 46e's Thaxx
