Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973449
04/16/11 03:35 AM
04/16/11 03:35 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote
If you read what hughes says
Well if Hughes says it then it must be correct...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973450
04/16/11 11:59 AM
04/16/11 11:59 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
But they will work on a mild iron head motor to reduce preload. Old method before your time.
I don't care if it is old backyard hack way to fix for over aggressive head milling or if someone did it 10 years ago and has 4 million miles since without an issue, the only reason to move the rocker shaft is to CORRECT rocker to valve geometry.
"Priced Each/ Usually Sold In Sets Of 10. Use to adjust rocker shaft height for achieving proper valve train geometry and pushrod length."
and pushrod length so in many cases milling the heads with stock rockers and pushrods makes the pushrods to long and these shims can be used to fix that!!!
I am right and rest my case!!
You can rest your case all you want Hughes, and Mancini, have it WRONG, yes they can be used to correct for pushrod length, but that is NOT their purpose.
Re: adjustable pushrods- a good idea or not? [Re: JohnRR] #973451
04/16/11 12:17 PM
04/16/11 12:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree with John. The rocker arm shims are supposed to be used to get the correct rocker arm to valve geometry. After setting up the correct rocker arm so the tip sweeps over the center of the valve end, then you measure pushrod length for the correct lifter pre-load.
Now if you already have a pushrod that is too long, adding the rocker arm shims will reduce the lifter pre-load, but change the rocker arm sweep pattern over the valve.
You could go as far as reducing the length of the valves to reduce lifter pre-load, but that would again change the rocker arm sweep pattern over the valve.
The reason I mentioned the Ford pushrod is it was the length I needed, and because it is a standard replacement pushrod, not custom length, I was able to find some for under $50 compared to well over $150+ for custom length pushrods.
