adjustable pushrods- a good idea or not? #973429
04/14/11 11:51 PM
04/14/11 11:51 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Due to head/block milling on my 383 (hydraulic lifters, stock mopar rockers) I need to either go with adjustable rockers (big $), shim the rocker arms up, or go with adjustable pushrods.
The guy who built the engine doesn't feel good about adj pushrods, even though is is a pretty mild (350 hp) motor that I baby. Anyone running adj pushrods? Had any problems? Are they a no-no? If they are ok, whose would you recommend?
Re: adjustable pushrods- a good idea or not? [Re: Mike H] #973430
04/15/11 12:16 AM
04/15/11 12:16 AM
IN
ahy Offline
ahy  Offline
IN
A good idea except you need only one adjustable PR. Use it to get the correct length and order a set of custom solid pushrods. Your local circle track (Chevy?) engine builder can order them, Smith Brothers can make them and Hughes can make them. Not a big expense and worth it.
Re: adjustable pushrods- a good idea or not? [Re: Mike H] #973431
04/15/11 03:52 AM
04/15/11 03:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How much milling was done?
I used Ford pushrods in my 383 after milling about 0.040" off the heads.
If you milled 0.040 to 0.060" this should work..
I think the standard length for the 383 is 8.555", the 351 Boss is 8.500". They are both ball-ball ends, just drilled for oiling through the pushrod.
Re: adjustable pushrods- a good idea or not? [Re: ahy] #973432
04/15/11 04:03 AM
04/15/11 04:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I never seen them used in a motor, use one to determine the correct lenght and have 16 made, no big deal.
Re: adjustable pushrods- a good idea or not? [Re: Challenger 1] #973433
04/15/11 07:31 AM
04/15/11 07:31 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
I have used adjustable pushrods on stock rockers. It was a 340 with a 6 pack and milled heads... It was a pain to adjust them with the maninfold right there in the way. I agree. Measure and order 16 made to the right lenght and be done with it.
Re: adjustable pushrods- a good idea or not? [Re: Mike H] #973434
04/15/11 08:29 AM
04/15/11 08:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
One of your choices is NOT a choice unless you ALSO have a rocker arm to valve tip geometry problem that needs to be corrected.
So your only other choices are adjustable rockers or adjustable pushrods and good adjustable pushrods are not real cheap. I just set up a 440 wit ha hyd. cam , new MP stamped steel rockers and adjustable pushrods , for the ultimate end cost it would have been more cost effective to just get a good set of adjustable rockers. That said there is nothing wrong with them , they are just tedious to initially setup .
Re: adjustable pushrods- a good idea or not? [Re: JohnRR] #973435
04/15/11 10:51 AM
04/15/11 10:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Adjustable push rods are fine to to use as measuring device and then only using 1. They would be/are a very weak link in the valve train/ Just take look at the size of the adjuster screw. Not a real hefty piece for sure.
IMO you would have had to have had quite a bit off the heads not to be able to get the stamped rockers to work fine. There is a lot of forgiveness in the hydraulic rocker.
Re: adjustable pushrods- a good idea or not? [Re: MoparforLife] #973436
04/15/11 12:16 PM
04/15/11 12:16 PM
JohnRR Offline
JohnRR  Offline
The heads and the block have had a lot cut off them, I trust the recommendation of my engine builder to run them and I'm sure if they were an issue Smith Bros. would have told me that it was not a good idea to use them when I ordered them.
I just saying he can run them as an alternative, but if I had to do this one over I would just bite the bullet and get adjustable rockers.
Re: adjustable pushrods- a good idea or not? [Re: ahy] #973437
04/15/11 01:20 PM
04/15/11 01:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....best advice, I had an adjustable pushrod decide to "let go" in motor at high rpm years ago, what a mess,....you can also buy DIY pushrod sets to make your own, should you want to tackle it on your own
Re: adjustable pushrods- a good idea or not? [Re: DAYCLONA] #973438
04/15/11 01:26 PM
04/15/11 01:26 PM
Cincinnati, Ohio
Cincinnati, Ohio
Like I said above, I've never seen adj PR used in a running motor, but I do lead a pretty sheltered life.
I would never even consider using them myself.
Re: adjustable pushrods- a good idea or not? [Re: Mike H] #973439
04/15/11 02:04 PM
04/15/11 02:04 PM
md
W
wicked Offline
wicked  Offline
W
md
I had ordered a stock replacement cro-mo type set custom length from Summit a few years ago, Think they ended up coming from Comp Cams or Crane and wasn't crazy money.
Re: adjustable pushrods- a good idea or not? [Re: Mike H] #973440
04/15/11 03:49 PM
04/15/11 03:49 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used them for years on my 440 and they are still on my buddies 440. best way to set them is on the engine stand with the intake off. second is n car intake off. I set them so they lightly ticked as I did a lot of racing. But they are not cheap.
http://www.summitracing.com/parts/CRO-70009-16/
well it was the way to go back in the day or the way I went dam in the eighties I paid 10 11 dollars each for MP ones.
still $160 verse buying rockers and pushrods is still less?? I don't see any for a 383 /400 so you would have to contact crower MP has not listed them for years.
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973441
04/15/11 03:54 PM
04/15/11 03:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hughes emgines sells shims you can shim your rockers up the .040 to go back to factory pre load!
http://www.hughesengines.com/Index/produ...amp;searchmode=
page 3!
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973442
04/15/11 04:08 PM
04/15/11 04:08 PM
Upper Midwest
Upper Midwest
seen many engines put back together with .040 or 0.050 off the heads with no problems using stock push rods and no shimming. And that was with the old shim type gaskets. Now you will have to take into consideration the thickness of the gsket to lesson the effects of the head/block trim.
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973443
04/15/11 05:00 PM
04/15/11 05:00 PM
JohnRR Offline
JohnRR  Offline
page 3!
WRONG !!!!!
Re: adjustable pushrods- a good idea or not? [Re: JohnRR] #973444
04/15/11 05:15 PM
04/15/11 05:15 PM
Upper Midwest
Upper Midwest
page 3!
WRONG !!!!!
They sell them but for a different purpose.
Re: adjustable pushrods- a good idea or not? [Re: JohnRR] #973445
04/15/11 05:24 PM
04/15/11 05:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
But they will work on a mild iron head motor to reduce preload. Old method before your time.
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973446
04/15/11 05:29 PM
04/15/11 05:29 PM
JohnRR Offline
JohnRR  Offline
I don't care if it is old backyard hack way to fix for over aggressive head milling or if someone did it 10 years ago and has 4 million miles since without an issue, the only reason to move the rocker shaft is to CORRECT rocker to valve geometry.
Re: adjustable pushrods- a good idea or not? [Re: JohnRR] #973447
04/15/11 09:24 PM
04/15/11 09:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If you read what hughes says
"Priced Each/ Usually Sold In Sets Of 10. Use to adjust rocker shaft height for achieving proper valve train geometry and pushrod length."
and pushrod length so in many cases milling the heads with stock rockers and pushrods makes the pushrods to long and these shims can be used to fix that!!!
I am right and rest my case!!
Re: adjustable pushrods- a good idea or not? [Re: Dodgem] #973448
04/15/11 10:14 PM
04/15/11 10:14 PM
Under My Car
Mopar_Country Offline
Under My Car
Measure, order correct length, install and drive it.
http://www.trendperform.com/index.php?go=measuring
