Page 3 of 3 1 2 3
Re: Yet another 383 question...I know Im killin you guys... [Re: Cab_Burge] #973336
04/16/11 11:52 AM
04/16/11 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doesn't anyone of you have a factory service manual? I do, maybe I'll look up the deck hieght on the magnum 383 in the morning and post what the manual says
I do , there isn't anything in it that I ever saw ? I have it here at work , I'll go look at it .
Re: Yet another 383 question...I know Im killin you guys... [Re: court9155] #973337
04/16/11 01:24 PM
04/16/11 01:24 PM
ogletownpa
3
383'D Offline
383'D  Offline
ogletownpa
I believe i seen that in the old mopar performance big block chrysler book. However I thought it was .015 positive. I,ll check after work.I think it was in the specs for the 68 383,s
Re: Yet another 383 question...I know Im killin you guys... [Re: JohnRR] #973338
04/16/11 02:53 PM
04/16/11 02:53 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
From the book of Mopar, as translated by me.
Yea as I pass through through the valley of Mopar
I shall fear no misinformation or hearsay,
conjecture and stupidy fall by the wayside.
As Mother Mopar’s Service Manuals and Tech
Bulletins guide me. My way is illuminated by
Common sense and the wisdom, and knowledge
of old timers who forged the path before me.
I comprehended the meaning of,
“Knowing the path and walking the path”.
Surely Chevy’s and Ford’s will die in my dust.
For mine is the meanest “Son-of-a bitchin” Mopar in the land.
Maynard
Re: Yet another 383 question...I know Im killin you guys... [Re: DartGTS] #973339
04/16/11 10:18 PM
04/16/11 10:18 PM
I looked in my 1969 Dodge service manual, it does not show the deck hieght or anything close to it I went to NHRA site and they show all the 1969 383 four barrel motors in Dodge and plymouth to have a .021 positive(above) deck hieght All the ones I remember working on( a long time ago) were no where near zero deck, let alone above
Re: Yet another 383 question...I know Im killin you guys... [Re: 451Mopar] #973340
04/17/11 02:59 AM
04/17/11 02:59 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
100ml (1ml=1cc) Buret listed on Amazon for $19.72
http://www.amazon.com/ACRYLIC-BURET-TEFL...7480&sr=8-1
A cheap buret clamp $4.60:
http://www.amazon.com/BURET-CLAMP-Rubber-covered-Buret/dp/B0018C2GEW/ref=pd_sim_misc_8
I also got some 1/2" thick Polycarbonate sheet 12"x12" for $20.96 - cut into 6"x6" squares for sheet to seal chamber:
http://www.amazon.com/Polycarbonate-Shee...7978&sr=8-5
I know I have a picture, just can't find it...
I'll take a pic and post it tomorrow.
Nice work. I thought I did some looking around but I guess I didn't look hard enough. I ordered a setup through Summit and paid waaayyy too much IMO.
Re: Yet another 383 question...I know Im killin you guys... [Re: rss] #973341
04/17/11 09:10 AM
04/17/11 09:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have the same summit kit but I like how he set his up with it attached to a thick piece of lexan , I see a mod in my future .
Same thing Cab , nothing in the shop manual on either piston height or deck height .
Re: Yet another 383 question...I know Im killin you guys... [Re: JohnRR] #973342
04/17/11 02:08 PM
04/17/11 02:08 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've had a few 68-69 383 hp motors through the years. 2 of them were above the deck with the original factory pistons. I never checked how far but one 68 motor I picked up had a set of 516 heads installed by someone. They had installed the .021 shim head gasket and the pistons had been kissing the heads. The motor still had the original factory pistons. Dave
Re: Yet another 383 question...I know Im killin you guys... [Re: quickd100] #973343
04/17/11 05:29 PM
04/17/11 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok , there are 2 people that have seen an engine that does not exist per any factory documentation ...
I'm not calling either of you 2 liars , but we need to see factory documentation.
Re: Yet another 383 question...I know Im killin you guys... [Re: JohnRR] #973344
04/19/11 07:52 AM
04/19/11 07:52 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Okay, this just further bolsters my search for a 68-69 4bbl 383 runner to stab in my Challenger. I'd read that positive deck bit in a couple Mopar mags as well, always wondered about it. All my 383's have been newer, and the one 69 i had was a 2bbl engine... i seem to remember that one being around .030" below deck on average. Mine was particularly bad though... deck heights were bloody all over the place.
SOOO... reading all this what i'm taking from this is that there IS a way to build a super-cheapo zero-deck or at least hokey quench engine. Find a 68-69 383 4bbl engine, pick a head gasket that will give around .040" quench and bolt some closed chamber heads on.
Is it really that simple...???
Also, are we talking ALL 68-69 383 4bbl engines here, or ONLY the actual HP engines...???
Re: Yet another 383 question...I know Im killin you guys... [Re: Pale_Roader] #973345
04/19/11 10:00 AM
04/19/11 10:00 AM
florida
74fldart Offline
74fldart  Offline
florida
dont even consider a 1971 engine unless its been rebuilt with some aftermarket pistons in the past. i have one and the piston deck height is .090 .
Re: Yet another 383 question...I know Im killin you guys... [Re: Pale_Roader] #973346
04/19/11 10:43 AM
04/19/11 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have a 69 383 2bbl piston here , it's the same height as the 4bbl piston but it has a Shallow round dish , if I get bored I'll cc it.
There are 2 68/69 383 4bbl engines , one is Stamped HP , the other is not , but it is an HP engine with the 2bbl cam instead of the 440/375HP cam.
So yes , 68-69 4bbl shortblock , felpro composite gasket and a closed chamber head with 80cc chamber will net you a 10.0ish engine. A 70 will have the piston a little lower in the bore , I don't know how much, 71 will be even worse it appears. Otherwise plan on decking if you use the Speedpro , Diamond or KB flat top to get zero.
If you weren't on the other side of the planet I have an original 69 383 HP shortblock that would do exactly what you want.
Re: Yet another 383 question...I know Im killin you guys... [Re: 74fldart] #973347
04/19/11 11:23 AM
04/19/11 11:23 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The 1971 383 (four barrel) I have has stock flat top pistons, no valve reliefs, 0.020 in the hole. The block is stamped 1970. Came out of a 1971 Newport.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Yet another 383 question...I know Im killin you guys... [Re: JohnRR] #973348
04/19/11 11:39 AM
04/19/11 11:39 AM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I had my 383hp in my SuperBee rebuilt a couple of years ago. I thought I did my homework. Stock pistons were .004 down in. My engine
builder realized that it must have had the deck mill .02 in it's life. I went with the KB400 with the dome and valve reliefs. Had my 906 heads gone thru and 3 angle valve job. New valves and retainers and locks and springs the compcam. 268 requires. I didn't calculate my numbers accurretly until after it was put together. With the 1.908 compression height of the KB400's and the stock pistons are 1.932 I realized after all the figuring I was only at 9.3 compression. What I should have done was had the heads milled .02 and went with the .02 steel head gasket and that would have put me near 10.0 compression. My future plans are to go with 440 source 80 cc heads to get the compression up to 10.0. Be careful with a zero deck and 80cc heads. Your pistons will need valve reliefs with that setup or you will most likely be tearing it back apart. Just my
Re: Yet another 383 question...I know Im killin you guys... [Re: Pale_Roader] #973349
04/19/11 11:58 AM
04/19/11 11:58 AM
California
court9155 Offline OP
California
I have said engine for you. It is in great shape too.
Anyway this isnt the classifieds section but I can tell you that all 68-69 4 barrel motors, regardless of HP or not, shared the same pistons.
The 2 barrel motors use different pistons. Just confirms everything JohnRR has been preaching. He is correct tho. The one motor that I have ripped apart was not positive deck height.
Dan
67 charger
Re: Yet another 383 question...I know Im killin you guys... [Re: court9155] #973350
04/19/11 05:00 PM
04/19/11 05:00 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
My guess would be NO. I haven't been looking, but my guess is that it wouldn't be too simple to find a 40+ year old 383 that didn't need to be overbored. The deck height advantage of the 68-69 383 comes from the compression height of the piston. Therefore, as soon as you bore the block you are in the market for new aftermarket slugs, none of which are made with a 1.932" compression height. As far as I know, closest thing you can get are the Sealed Power 2315s, which are at 1.920".
Seems to me like the "simple" thing would be to have the block machined to get the zero or positive deck height you are looking for, but who knows, maybe there is an endless supply of low mile 68-69 383 shortblocks where you live.
Going my route, you would also be able to square up your block to ensure consistent deck heights for each cylinder, which would probably not be the case for an untouched factory block.
Re: Yet another 383 question...I know Im killin you guys... [Re: rss] #973351
04/19/11 05:38 PM
04/19/11 05:38 PM
California
California
It is hard to find a low mileage 68-69 383 Im sure, let alone one that doesnt need bored.
I do have one that is SAID to have 35k miles on it and has been sitting on a pallet since 1975 SUPPOSEDLY. I wasnt too sure of this claim, but after selling the HP manifolds, carb, air cleaner and valve covers I believe it. The motor looks to be in great shape. Probably a runner but definitely a good candidate for a brush hone, rings, polished crank and bearings.
Dan
67 charger
Re: Yet another 383 question...I know Im killin you guys... [Re: court9155] #973352
04/19/11 06:09 PM
04/19/11 06:09 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
all 5 of mine are 50K or less,still showing cross-hatch in the cylinders,just a black carbon ridge at the top. but,mine have a good home,and are not leaving the nest anytime soon.....
Re: Yet another 383 question...I know Im killin you guys... [Re: superbyrd] #973353
04/19/11 06:19 PM
04/19/11 06:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But they are underpowered junk , why would you keep them ?
Re: Yet another 383 question...I know Im killin you guys... [Re: JohnRR] #973354
04/19/11 06:23 PM
04/19/11 06:23 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
2 words.......boat anchors.....well,that and i'm a pack rat....
Re: Yet another 383 question...I know Im killin you guys... [Re: superbyrd] #973355
04/19/11 07:57 PM
04/19/11 07:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You must have a lot of boats .
Page 3 of 3 1 2 3
