Mopar performance New crate 3rd gen hemi???
#973058
04/14/11 09:35 AM
04/14/11 09:35 AM
Posts: 2,826 NY usa
540challenger
NY usa
Anybody have any info on the new 3rd gen 426 Alum. block crate hemi from mopar??? Like what heads they come with, computer, wiring harness. forged piston??? etc?? When they will be available and how much they run?? http://www.mopar.com/performance/muscle/crate_enginesI was looking into arlington "shophemi" but they want any where from 14g-15g plus 3000.00 for a core
Re: Mopar performance New crate 3rd gen hemi???
[Re: 540challenger]
#973059
04/14/11 01:39 PM
04/14/11 01:39 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Basic rundown is 10.7:1 cr, Callies rods, Callies crank, Mahle Forged pistons, 6.1 heads, the 392 cam which is 279/285 -.584/.552, a stock 6.1 intake, an oem stock 6.1 throttle body, no wiring harness, no computer, the aluminum block (which is about 5k by itself bare), a stock 6.1 oil pan, stock 6.1 valve covers, stock 6.1 coil packs, and so on.
Retail is 13,675.00, and they are available right now on a build to order basis.
If you're researched it you've probably noticed it is the lowest priced complete 426CI Gen 3 on the market, and an additional benefit is it is 98 lbs lighter than stock because of the aluminum block.
Like most other Mopar Performance crate engines, it carries a 90 day warranty that begins the day the engine is picked up.
That's about all the info I have but if you need anything else just ask, should be able to find out anything you'd want to know.
[Re: caper]
#973061
04/14/11 03:11 PM
04/14/11 03:11 PM
ZIPPY
S.E. Michigan
Conservatively rated at 540hp/530tq.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#973062
04/14/11 03:57 PM
04/14/11 03:57 PM
Posts: 2,826 NY usa
540challenger
NY usa
WOW Thanks great post Zippy thank for taking the time to post.
[Re: 540challenger]
#973063
04/14/11 10:55 PM
04/14/11 10:55 PM
ZIPPY
S.E. Michigan
Glad to help, let me know if you need any more info.
Rich H.
Esse Quam Videri
[Re: SRT6776]
#973065
04/15/11 09:07 AM
04/15/11 09:07 AM
Posts: 2,826 NY usa
540challenger
NY usa
OP you can buy a 540HP 392 crate as well IIRC
Thanks you for the info, but when i looked i think the price of the 6.4L crae was right around 12,500 at that point i rather go with the ALum block and cubes.
[Re: ZIPPY]
#973066
09/23/11 11:57 PM
09/23/11 11:57 PM
Posts: 8 north of detroit Michigan
Grimmey71
Do you know if the crate still uses oil squirtters? Also are all accessories interchangeable between the 5.7's? Thanks for any info, I am getting close to pulling the plug and ordering one and need to get all my ducks in a row.
[Re: 540challenger]
#973067
09/24/11 12:39 AM
09/24/11 12:39 AM
Triple Threat
Renton Washington
Where are the Crate engines built now a days? Have the assembly issues of the past been addressed? I know for quite some time It was said that if you buy a crate engine you need to take it apart and check it before running it.
