New SIXPACK STROKER Motor
#972905
04/13/11 11:29 PM
04/13/11 11:29 PM
Posts: 38 Alexandria, VA
easygoingjuan
Alexandria, VA
Hello everyone, I just wanted to share a few pics of my new motor, a high compression stroked out 440 sixpack built by none other than Bob “The Man” Karakashian aka Mr. 6pk and his faithful sidekick/daughter Kim! I’m excited beyond belief. Mr. 6pk did an outstanding job and exceeded my hopes and expectations! He always kept my best interest in mind, answered all of my questions, and discussed every aspect of the build with me in detail. A true Mopar guy, Racer, and Friend. You’re one in a million Bob, thank you!
I’ll do my very best to keep everyone posted.
Re: New SIXPACK STROKER Motor
[Re: easygoingjuan]
#972909
04/14/11 11:52 AM
04/14/11 11:52 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Hello everyone, I just wanted to share a few pics of my new motor, a high compression stroked out 440 sixpack built by none other than Bob “The Man” Karakashian aka Mr. 6pk and his faithful sidekick/daughter Kim Karakashian! I’m excited beyond belief. Mr. 6pk did an outstanding job and exceeded my hopes and expectations! He always kept my best interest in mind, answered all of my questions, and discussed every aspect of the build with me in detail. A true Mopar guy, Racer, and Friend. You’re one in a million Bob, thank you!
Heads?, Cam?
Now, it’s time for me to put this bad boy in the Bee and see what she’ll do!!!!!!!!!!!!!!!!!!! I’ll do my very best to keep everyone posted.
[Re: BobR]
#972911
04/14/11 11:19 PM
04/14/11 11:19 PM
easygoingjuan
Alexandria, VA
Heads?, Cam?
Cam is a custom Mr.6pk grind as well as the heads. Thanks for the interest.
Juan
[Re: 70sixpkrt]
#972912
04/14/11 11:22 PM
04/14/11 11:22 PM
easygoingjuan
Alexandria, VA
What are the specs of the motor?
Thank you for the interest but I thought I'd leave the specs for the track.
[Re: Mr.Yuck]
#972913
04/14/11 11:23 PM
04/14/11 11:23 PM
easygoingjuan
Alexandria, VA
NIZZZZE but I'm bais
Hello, that's a nice set up you have in your Charger. Thanks for the compliment.
Juan
[Re: hemigod426]
#972921
04/15/11 10:35 AM
04/15/11 10:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
let you know soon. I had an issue with the Moroso valve covers and the H/S rockers. It's not quite full weight. I has a glass hood. front valance and no heat/ac box. I think it should run 11.50's once I get it tuned in.
do the harland sharp rockers fit with stock 1970 covers just bought a set of 1.5s for my 1970 440 sixpack motor?
I'm going to say no. Not w/o some serious .
[Re: hemigod426]
#972922
04/15/11 08:30 PM
04/15/11 08:30 PM
Posts: 731 NY
XXHEMI
NY
The Harland Sharps with work with easy mods. One would be to remove the baffel completly the other is to just drill 3/8th holes where the studs are. If you remove the baffel completly you should make a sheild at least where the breather is. Other then that it's a home run.
Jaun looks great good luck!
Ed
