Re: ALTERNATORS
[Re: MIKES_DUSTER]
#972627
04/13/11 05:31 PM
04/13/11 05:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Add up your amp draw then add a extra 15%, that would be what I would use as a minimum(more takes more power to turn)... most of the guys like the 1 wire because its easy to hook up... myself I dont care for them... if it has a regulator problem you either buy a new one or tear it apart and fix it... it you have a external you buy a reg and your back on the road. At 11 volts you have a problem... full field the reg and see if the alt is putting out Also when I say all of the draw items that means lights and everything
Re: ALTERNATORS
[Re: MIKES_DUSTER]
#972629
04/13/11 05:41 PM
04/13/11 05:41 PM
MR_P_BODY
When I put the lights on,the volts drop to 10. I dont have any of them hooked up with relays,would that help if I did that??
Before I put on the electric water pump and fan,I was ok but now,im not.
Full field the reg and see what the alt puts out, with everything off and at about 1500 rpm what voltage do you have
Re: ALTERNATORS
[Re: Sport440]
#972633
04/13/11 08:26 PM
04/13/11 08:26 PM
I have an extra east coast 1 wire mini alternator new if you want to go that route. they work great. pm me if interested.
Re: ALTERNATORS
[Re: MIKES_DUSTER]
#972635
04/13/11 10:32 PM
04/13/11 10:32 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Mike I run a 90's style denso alt. from a dakota, they come in 90 120 or 140 amp and use a 2 wire external field and charge well at a lower rpm. You can use a mopar 72 up style regulator and it works great. Mr P is right you have to have more altenator than load or you will have to charge the battery, this can be ok for a race only set up but not for me. One of the good things about this alt/reg set up is you can buy the parts anywhere when ya need it. There is a lot to the 1 wire vs ext. field ask if you want more info. Hope this helps.
"Just a Bracket car dressed up like a streetcar"
Re: ALTERNATORS
[Re: Quicktree]
#972638
04/13/11 11:29 PM
04/13/11 11:29 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I had an upgraded(80 amp) stock alternator and known good battery and still had constant trouble when trying to run everything electric.
I think that alternator would have been fine had I bypassed the amp meter and the bulkhead connector the first time around. Instead I just made double sure and went for an even better alt and took out ALL the factory wiring that had to do with the charging system.
Bieng how I manage a battery distributorship I can't take any chances on bieng dead in the lanes again lol.
68 Barracuda Formula S 340
Re: ALTERNATORS
[Re: Bad340fish]
#972639
04/14/11 09:26 AM
04/14/11 09:26 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I used a late model GM alternator. I honestly can't remember the series. It works well even with a underdrive pulley. It charges at 14.4 volts with all accessories on at anything off idle. I also eliminated all of my stock wireing with the exception of the lights and wipers.
Those brackets...are they something you made, or is this some form of conversion kit I can buy?
Re: ALTERNATORS
[Re: MIKES_DUSTER]
#972641
04/14/11 11:27 AM
04/14/11 11:27 AM
Posts: 7,506 Az
Crizila
Az
Weather you run a one wire or the stock external regulator set up, it won't make any difference in regards to alternator output. If you are running a stock alternator / pulley set up, you probably won't have enough juz at idle ( even if everything is up to snuff ). Between the fuel / water pump, fan ( your biggest draw ), and ignition alone you are probably pushing around 60 amps. No stock Chrysler alternators can push that number at idle ( below 1000 engine rpm ). You could try going to a smaller alternator pulley ( unless you already are running a 2.5" pulley which is the smallest you will find ), a larger crank pulley, or buy a later model alternator ( Denso, etc ) that has a high rise time - more juz at idle. I ran in to similar problems as you, and my schedule calls for 3-4 night races ( add lights ). I also race at some pretty high temps here in the AZ area. I dumped my electric fan ( saved 28 amps ) and now run a large 19" flex fan - cools better also. It cost me about a tenth, but I don't have charging or cooling problems. I run a 1 wire Chrysler style alternator ( square back ) with a 5" Moroso pulley on it.
Fastest 300
Re: ALTERNATORS
[Re: POS Dakota]
#972643
04/14/11 01:29 PM
04/14/11 01:29 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I also used a late model GM AC Delco alternator, the CS144. They're used in Escalades, Suburbans etc and put out some serious amperage at idle, in the 115amp range at idle and The one I have was rewound and peaks in the low 200 amp range at fast idle. It's internally regulated too.
There are $35 adaptors available to adapt it to the stock Mopar brackets. You can see it in this pic. I'm using the Buschillon hidden a/c bracket hardware and rerouted the drive belts on their system to increase the radius of belt to pulley contact; but it all bolted right in nicely.
It's not yet the most popular conversion, but it is the best bang for your alternator buck.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: ALTERNATORS
[Re: jbc426]
#972644
04/14/11 01:36 PM
04/14/11 01:36 PM
Bad340fish
Tulsa OK
Thanks to the above post I remembered what my alternator was. Its a CS130 GM.
