1971 400 Compression Ratio? #972571
04/13/11 02:17 PM
04/13/11 02:17 PM
New York
R/T1968R/T Offline OP
New York
Picked up a low mileage 1971 400 motor. It is the #230 casting thick web block. Was the compression ratio the same as all 400s....8.2 I heard the early 400s were closer to 9.1 Any truth to this?
Re: 1971 400 Compression Ratio? [Re: R/T1968R/T] #972572
04/13/11 02:36 PM
04/13/11 02:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If anything, the advertised CR is higher than the actual CR by about half a point.
Re: 1971 400 Compression Ratio? [Re: John_Kunkel] #972573
04/13/11 03:04 PM
04/13/11 03:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said , piston in that block is about .100 in the hole, you'll be lucky to have 8.0.
I just ran some numbers , had to ASSuME a few numbers but compression is approx. 7.63 - 7.75 depending on head chamber volume .
Re: 1971 400 Compression Ratio? [Re: JohnRR] #972574
04/13/11 03:13 PM
04/13/11 03:13 PM
N.J. north west
1972challenger Offline
N.J. north west
You would be luck if it's 7.5 to 1
Re: 1971 400 Compression Ratio? [Re: 1972challenger] #972575
04/13/11 03:15 PM
04/13/11 03:15 PM
Re: 1971 400 Compression Ratio? [Re: R/T1968R/T] #972576
04/13/11 03:51 PM
04/13/11 03:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
take your conclusions:
-stock pistons are around 0.100-0.110 below the deck
-open heads are around 90 cc
These measurements are ACTUALLY AND PERSONALLY checked by me
then, IF MORE needed, add the gasket thickness.
