Re: 1971 400 Compression Ratio?
[Re: R/T1968R/T]
#972572
04/13/11 02:36 PM
04/13/11 02:36 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If anything, the advertised CR is higher than the actual CR by about half a point.
[Re: 1972challenger]
#972575
04/13/11 03:15 PM
04/13/11 03:15 PM
You would be luck if it's 7.5 to 1
[Re: R/T1968R/T]
#972576
04/13/11 03:51 PM
04/13/11 03:51 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
take your conclusions:
-stock pistons are around 0.100-0.110 below the deck -open heads are around 90 cc
These measurements are ACTUALLY AND PERSONALLY checked by me
then, IF MORE needed, add the gasket thickness.
