04/13/11 01:34 PM
04/13/11 01:34 PM
Knoxville TN
sonudasouf Offline OP
Knoxville TN
... [Re: sonudasouf] #972539
04/13/11 01:34 PM
04/13/11 01:34 PM
Knoxville TN
Knoxville TN
... [Re: sonudasouf] #972540
04/13/11 01:35 PM
04/13/11 01:35 PM
Knoxville TN
Knoxville TN
... [Re: sonudasouf] #972541
04/13/11 03:25 PM
04/13/11 03:25 PM
Knoxville TN
Knoxville TN
Re: Help figuring out what Master Cylinder I have [Re: sonudasouf] #972542
04/13/11 03:30 PM
04/13/11 03:30 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Looks like a later model b/e-body master cylinder ( '71-'74 ). I know the inlet for the tubes on the '71 and up b-body were to the outside unlike the '69 model year..
Troy
Houston Mopar Connection Club
Re: Help figuring out what Master Cylinder I have [Re: sonudasouf] #972543
04/13/11 03:30 PM
04/13/11 03:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What you have is a generic aftermarket casting , the booster is also not a factory installed Bendix unit .
Just order a master cylinder for a 69 Charger with Disc brakes and Big block , not hemi and see if you get one that looks closer than that one.
Re: Help figuring out what Master Cylinder I have [Re: JohnRR] #972544
04/13/11 03:52 PM
04/13/11 03:52 PM
Houston, Tx
Houston, Tx
Be warned, if you get a Cardone product, be careful. I went through 3 and never found a good one. I believe in hindsight and further coaching, I should have checked the rear piston-2-pushrod relationship. The rear piston on the new reman. master cylinder was slightly different than my older OEM MC. If the front calipers lock up you or won't release, you may try slightly shortening the booster push rod into the master cylinder.
Troy
Re: Help figuring out what Master Cylinder I have [Re: hemi68charger] #972545
04/13/11 07:14 PM
04/13/11 07:14 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Take a look at Raybestos MC 36283 from Rock Auto, I've got that one on a 67 Coronet w/disc w/bendix booster and works great
Semper Fi
... [Re: GOLDMYN] #972546
04/14/11 01:03 PM
04/14/11 01:03 PM
Knoxville TN
Knoxville TN
Re: Help figuring out what Master Cylinder I have [Re: sonudasouf] #972547
04/14/11 01:33 PM
04/14/11 01:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It looks similar to the cardone 10-1572 I just put on my 74 D100.
