challenger under-flip top fuel caps? #972479
04/13/11 10:56 AM
04/13/11 10:56 AM
Bloomington, IN
HoosierTA Offline OP
Bloomington, IN
I posted this on Q and A and had no response. Does anyone know the Stant brand part numbers for the fuel caps for under the flip tops on E bodies?
Thanks.
'70 Challenger R/T 383
'16 Hemi Durango SSV (work vehicle)
'15 Ram Police SSV
Re: challenger under-flip top fuel caps? [Re: HoosierTA] #972480
04/13/11 11:18 AM
04/13/11 11:18 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are you thinking locking or not? From what I understand, they were all locking?
Re: challenger under-flip top fuel caps? [Re: Challenger 1] #972481
04/13/11 12:24 PM
04/13/11 12:24 PM
Bloomington, IN
Bloomington, IN
Yes, I think the factory was a locking cap. Some time ago, someone posted the part numbers for the Stant brand caps that you can get at Carquest.
I got one right away for my car, but a local guy is putting the finishing touches on a 73 Challenger and asked about it.
'15 Ram Police SSV
Re: challenger under-flip top fuel caps? [Re: HoosierTA] #972482
04/13/11 12:46 PM
04/13/11 12:46 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I'm at work now, but I'll get you the proper Stant # when I get home tonite. It is on my 73 Challenger, and is a locking cap.
I saw your first post, but thought you wanted the Stant # for the 70 Challengers that you own. The 70 is different, as it has different slots on the filler neck opening.
Re: challenger under-flip top fuel caps? [Re: 318 Stroker] #972483
04/13/11 01:18 PM
04/13/11 01:18 PM
Bloomington, IN
Bloomington, IN
That's something I wasn't aware of! I can tell by his photos the car is a 73/74 model.
'15 Ram Police SSV
Re: challenger under-flip top fuel caps? [Re: HoosierTA] #972484
04/13/11 01:44 PM
04/13/11 01:44 PM
Cincinnati, Ohio
Cincinnati, Ohio
71 on the left, same as 70 with Ca emissions. 35037 fit's 70, 72-73. The other one fit's 71 and 70 with Ca emissions.
Re: challenger under-flip top fuel caps? [Re: Challenger 1] #972485
04/13/11 01:53 PM
04/13/11 01:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I know a stant or federated pt # 46145 cap will work for a 1970 Challenger with the CA emissions pkg
1970 Challenger non CA emissions is a different tube and the caps are not interchangeable.( sorry I do not know that ones pt # )
1971 and newer I'm of no help
Re: challenger under-flip top fuel caps? [Re: gtx6970] #972486
04/14/11 10:21 AM
04/14/11 10:21 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I need one for my 71 too, looks like its still available!! Thanks!
Re: challenger under-flip top fuel caps? [Re: wally426ci] #972487
05/13/11 01:37 PM
05/13/11 01:37 PM
Up in the North and Far Away
AutoEngineer Offline
Stant 10571 is equal to Carquest 35037
