Trans in a 74 E body 360 727 (?) BB compatible?
#972374
04/13/11 01:30 AM
04/13/11 01:30 AM
Posts: 2,623 Ca Registered: Mar-2001
hemiallen
I did some searching, but to no avail.
If my memory serves, my 74-360 Challenger should have a 727, and I also believe it should bolt to a 440 also, with a swap to the correct converter...?
I guess my 2+ year haitas didn't do me well, I believe I looked into this when I purchased a BB water pump housing in preperation for my son to want to upgrade to a 440 as soon as we get the car driving....
I also think all I need are BB motor mounts for the swap?
Allen
'05 Quad cab hemi truck- Flame red- magnaflow exhaust
70-440 cuda-
74-360-4v Challenger- new driver car
EX vehicles:
66 charger Drag car- 10.80 at 123 mph
57 imperial 392 Hemi
1960 Sanger V drive- mondello-built 392 hemi
Re: Trans in a 74 E body 360 727 (?) BB compatible?
[Re: hemiallen]
#972375
04/13/11 01:34 AM
04/13/11 01:34 AM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
Big block uses a different bellhousing pattern. There are small block and big block 727 transmissions. 727 convertors usually interchange, some years are different. You need a different trans to bolt to a big block if yours was behind a 360.
[Re: SNK-EYZ]
#972376
04/13/11 02:04 AM
04/13/11 02:04 AM
hemiallen
For some reason I thought there were 727's with both patterns for the 74's....
I think the converter would be wrong for the ~ 500 hp the 440 should produce, but I do have 2 BB 727's but both have no low band apply valve bodies in them.
Allen
70-440 cuda-
EX vehicles:
[Re: hemiallen]
#972377
04/13/11 07:25 AM
04/13/11 07:25 AM
Posts: 74,977 U.S.S.A.
JohnRR
U.S.S.A.
Allen
They both have manaul shift valve bodies ? If you don't want that you can just swap in the one from your 74 , wit ha shift kit added , or buy one from Cope.
[Re: JohnRR]
#972378
04/13/11 11:26 AM
04/13/11 11:26 AM
hemiallen
Thanks John.
Sounds like a good deal on the swap, should be easy. I have my CRT transmission in the Cuda.......
Sounds like an engine-trans swap is in the works. My son got the Carb on the 360 rebuilt and called to tell me the car has Posi.... I told him NS shirlock, the tag on the diff says 3.55 SG.... So possibly the 360 may have enough steam if he got rubber in both wheels.... But he is , for once, researching the net on HP for the 8:1 440, ported 916 heads and timeslips...
Allen
70-440 cuda-
EX vehicles:
