Backing plate nut and bolt
#972320
04/12/11 11:56 PM
04/12/11 11:56 PM
Posts: 386 Maryland
reno340
Maryland
I am looking for a backing plate nut and bolt for my 1972 Plymouth Duster 340. Therte are 4 total but the one I want is completely different than the other 3. It is the one on the bottom and toward the rear of the car. The reason I need it is that the nut is thinner to avoid hitting the self adjuster cable. The nut and bolt are somewhat stripped out and I don't want anything bad to happen. (I know there are 3 more but I worry) Could someone help me find a couple?
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Backing plate nut and bolt
[Re: JohnRR]
#972324
05/05/11 12:15 AM
05/05/11 12:15 AM
Posts: 386 Maryland
reno340
Maryland
sorry, I forgot to mention it is on the front drum brakes. it is the lower rear bolt and nut to the backing plate. the nut is pretty thin to avoid interference w/ the brake shoe.
[Re: reno340]
#972325
05/05/11 10:12 AM
05/05/11 10:12 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
You will probably need to put a want ad in the A body parts section , that's not something you would find new in the correct configuration. And don't drive the car till you get it , that bolt is also holding the ball joint to the spindle.
