413 rebuild #972114
04/12/11 06:04 PM
04/12/11 06:04 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Where is the best place to buy new pistons, rings, bearings, etc., to rebuild a 62 413 motor?
Re: 413 rebuild [Re: TrueTripleX] #972115
04/12/11 06:59 PM
04/12/11 06:59 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Don't know if it's the best place,but you might try Kanter at kanter.com. Phone 973-334-9575.They list rebuild kits for 413's. Never bought anything from them,just have one of their catalogs.
Re: 413 rebuild [Re: TrueTripleX] #972116
04/12/11 07:26 PM
04/12/11 07:26 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Most everything is still available except some good pistons. I have got my feelers out on getting some better higher performance compression-distance pieces made ... more in the lines of a 6 pack piston.
Re: 413 rebuild [Re: dOrk !] #972117
04/13/11 05:47 PM
04/13/11 05:47 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
I ordered some yesterday off of Summit, Sealed Power 238P, They have a 2.000 Compression Height, but came to 9.85:1 compression with my 516 closed chamber heads. I measured the heads and came up with 69 cc's, and Summit has a compression calculator that works really well. What year of 413?
Re: 413 rebuild [Re: Hotlumpy] #972118
04/13/11 05:58 PM
04/13/11 05:58 PM
Ball Ground GA
Ball Ground GA
It's a 62 motor in a 62 300 convertible,
Re: 413 rebuild [Re: TrueTripleX] #972119
04/13/11 08:57 PM
04/13/11 08:57 PM
California
Hotlumpy Offline
Hotlumpy  Offline
California
If the heads are factory, they should be closed chamber 516 heads, and the Sealed Power 238P Pistons should work. I didn't have any luck through anyone but Summit, and the .040 over Pistons I ordered are not shipping out until 4/26. Good luck! Here is a link
http://www.summitracing.com/parts/SLP-W238P40/
Compression calculator is on this link. Pistons are .085 deck clearance with the 2.000 compression height, have your heads cc'd and you're on your way.
Re: 413 rebuild [Re: Hotlumpy] #972120
05/04/11 01:58 PM
05/04/11 01:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Lumpy, Do your 516 have cast in rocker stands, or the aluminum stands that are on the rocker shafts?
