Need valve help- stock 69 426 hemi #972004
04/12/11 02:53 PM
04/12/11 02:53 PM
Kent, WA
triple_green Offline OP
Kent, WA
Working with a mechanic-this is way beyond my skill level:
What are the valve adjustment specs? Esp. height?
what is the correct pushrod length? we seem to have two sets?
thanks!
Mark
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Need valve help- stock 69 426 hemi [Re: triple_green] #972005
04/12/11 03:40 PM
04/12/11 03:40 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Don't remember which is which but Hemi's use different length pushrods for intake and exhuast , I think the exhaust is the longer one .
What do you mean by HEIGHT ???
Re: Need valve help- stock 69 426 hemi [Re: JohnRR] #972006
04/12/11 03:47 PM
04/12/11 03:47 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
If I remember correctly-
exhaust- .024
intake-.022
Re: Need valve help- stock 69 426 hemi [Re: Kirby] #972007
04/12/11 05:33 PM
04/12/11 05:33 PM
michigan woods
imfixinmopars426 Offline
michigan woods
is the cam original? solid or hydro? any cam card w/ the cam/engine? more info for proper help,and answers.what length p/rods do YOU have?...mike
Re: Need valve help- stock 69 426 hemi [Re: imfixinmopars426] #972008
04/12/11 06:31 PM
04/12/11 06:31 PM
Kent, WA
Kent, WA
soild lifters; stock cam
Re: Need valve help- stock 69 426 hemi [Re: triple_green] #972009
04/13/11 09:22 AM
04/13/11 09:22 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Longer push rods are for the exhaust. Was the engine originally built using the push rods you have ?? Or are you piecing something together ?
Jig it up and check to make sure the push rods you have are the right ones for the engine.
logan426
Re: Need valve help- stock 69 426 hemi [Re: MLR426] #972010
04/13/11 11:03 AM
04/13/11 11:03 AM
Kent, WA
Kent, WA
I found the orig pushrods, so the engine builder put new ones in. I am taking the old ones over to the shop tonight and we will check whatis in there now.
The guy who did the rebuild was not a hemi specialist....mostly does Chevys. I think I screwed up having him do the rebuild.
mark
Re: Need valve help- stock 69 426 hemi [Re: triple_green] #972011
04/13/11 10:58 PM
04/13/11 10:58 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Actually .028 and .032 are the specs on a stock Hemi solid. I usually run them at .024 and .028 though. The pushrods will be obvious when he assembles the engine, hope he checks for proper geometry and rocker clearance, alignment etc.
Sheldon
Re: Need valve help- stock 69 426 hemi [Re: RUNCHARGER] #972012
04/14/11 09:52 AM
04/14/11 09:52 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Yes Sheldon that's why I said to mock it up and check them for correct length, etc.
logan426
