some help starting new engine #971673
04/11/11 11:16 PM
04/11/11 11:16 PM
california
drumcat Offline OP
drumcat  Offline OP
california
starting engine for the first time,I have spark at the coil wire and plugs,primed carb will not fire,the starter cranks but kills the battery in just a few minutes kind of frustrated dont know whats going on?
Re: some help starting new engine [Re: drumcat] #971674
04/11/11 11:18 PM
04/11/11 11:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check to see if maybe the distributor is 180* out.
Re: some help starting new engine [Re: drumcat] #971675
04/11/11 11:18 PM
04/11/11 11:18 PM
dist/timing
Re: some help starting new engine [Re: RapidRobert] #971676
04/11/11 11:44 PM
04/11/11 11:44 PM
california
drumcat Offline OP
drumcat  Offline OP
california
TDC,pushing pressure out on number one cylinder stroke right?
Re: some help starting new engine [Re: RapidRobert] #971677
04/11/11 11:49 PM
04/11/11 11:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
dist/timing
Sometimes it pays to have a helper gently rotate the distributor around a little while cranking a new engine over.
Re: some help starting new engine [Re: drumcat] #971678
04/12/11 12:18 AM
04/12/11 12:18 AM
Correct, then hand turn it more CW till you are at 10BTDC then w vac can roughly located turn housing till the magnet is dead even w the nearest tooth AND the rotor is under (or near under) the #1 cap terminal. If starting from scratch MAY need to reclock the inter gear a tooth and ideally want to maintain the OE plug wire routing for standardization and it lets the wires lay neatly. EDIT extra: turn the housing 360 & find the tooth that protrudes the most (least reluctor gap) then put the magnet dead even w it & if you have a vac pump (good tool to have) pump up the can slowly thru it's travel and move the housing (magnet) at the same time to keep them dead even till the clearance is the closest and set the gap at .006-8
Re: some help starting new engine [Re: RapidRobert] #971679
04/12/11 12:25 AM
04/12/11 12:25 AM
california
drumcat Offline OP
drumcat  Offline OP
california
Thank you guys...putting charge on battery will start again tomorrow.
Re: some help starting new engine [Re: drumcat] #971680
04/12/11 01:07 AM
04/12/11 01:07 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I dont want to piss on your wheaties here, but if you have been cranking on a motor long enough to wear down the battery, you may have wiped out the cam and lifters. All it takes is 3 or 4 revolutions of a motor to WIPE off the assembly lube and from there, the cam lobes are running metal to metal.
To test for spark, you can pull the distributor out of the motor and pull a plug wire off a plug. Stick a spare plug in the loose wire and turn the ignition switch ON. Now spin the distributor shaft. If you see the plug arc, then you need to determine where TDC is and then stab the distributor. If you want a diagram, look at Hughes Engines website in the camshaft section.
I hope for your sake that the cam is okay. Priming the system wont help either, since the cam and lifters are SPLASH lubricated by oil slung from the crankshaft. Keep us in the loop.
Re: some help starting new engine [Re: Kern Dog] #971681
04/12/11 01:16 AM
04/12/11 01:16 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Use the TDC mark to set the distributor where it will start until you get the light on it. You are just literally shooting for TDC as the timing or slightly BTDC.
Easiest way I know to hit the mark the first time is to have a reliable TDC mark, put the intermediate shaft in so that it is at 9 and 3 (straight across) and then put the distributor in. Just make sure that the rotor is pointing to the #1 terminal and it should hit first try if everythign else is in order.
Check and make sure you have a good ground. I've seen engine put back in cars and they crank slow when they have a ground left off or too small a wire. Easy thing to miss in the excitement of a first fire.
I want my fair share
Re: some help starting new engine [Re: SomeCarGuy] #971682
04/12/11 06:29 PM
04/12/11 06:29 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Thanks guys, The cam and lifters i carried over from the previous engine....i am running one ground strap from the engine to the K member,Do i run from engine to body as well?....problem now is i do not have spark from the coil wire....power to +side is there although seemingly weak...a way to test coil? my electric knowledge clearly is lacking,so any and everything will be absorbed...but first i need some power.
Re: some help starting new engine [Re: drumcat] #971683
04/12/11 06:34 PM
04/12/11 06:34 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Some car guy by 9&3 do you mean pointing from cylinder bank to bank or parallel with the cam(as i have it)?
Re: some help starting new engine [Re: drumcat] #971684
04/12/11 06:37 PM
04/12/11 06:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
run a ground from the engine to the body. you do have one from the bat to the engine, right?
Re: some help starting new engine [Re: drumcat] #971685
04/12/11 06:40 PM
04/12/11 06:40 PM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
Running parallel to the cam
Re: some help starting new engine [Re: drumcat] #971686
04/12/11 06:41 PM
04/12/11 06:41 PM
michigan woods
imfixinmopars426 Offline
michigan woods
ok...first,ground to engine from batt.smaller groung from back of engine to firewall,or body ground,not really need for x-member gnd.
is there key power to resister on firewall? if so,is there power from neg coil,form resistor? resisters go bad.
bring engine up on #1,front cyl,drivers side,and match the plug wire tower on cap to rotor.like above might have to pull dist,and realighn the drive gear/oil pump shaft,to get proper plug wire location. if all is ok?
*got spark? is it electroic,or points?
*a slow starter on a new engine is a pain! if the timing is off,or 180deg out,the engine might turn over hard,or stupid when starting.
let us know how it going,good luck,mike
Re: some help starting new engine [Re: imfixinmopars426] #971687
04/12/11 07:00 PM
04/12/11 07:00 PM
california
drumcat Offline OP
drumcat  Offline OP
california
No engine to battery ground,Battery is in the trunk(grounded to a frame rail) will pull the ground of the K and relocate it to the body...Auto Zone said my battery was good(5+years old and sitting)its good for about 2 minutes of cranking(starter seems to be at speed) so either the battery is no good or another problem has shown itself,i want to implement the timing suggestions but need some steady juice.
Re: some help starting new engine [Re: drumcat] #971688
04/12/11 07:02 PM
04/12/11 07:02 PM
california
drumcat Offline OP
drumcat  Offline OP
california
orange box ignition.
Re: some help starting new engine [Re: imfixinmopars426] #971689
04/12/11 07:41 PM
04/12/11 07:41 PM
california
drumcat Offline OP
drumcat  Offline OP
california
I have key power to the resistor,and it carries over to the opposite side of the resistor,still no coil spark.
Re: some help starting new engine [Re: drumcat] #971690
04/12/11 08:17 PM
04/12/11 08:17 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Make sure the orange box has a good ground.
The slot in the drive can be ALMOST parrallel and it is on the wrong stroke. Off just slight bit. Kind of hard to describe but once you see it positioned the wrong way and then the correct way you won't forget.
Then
Re: some help starting new engine [Re: drumcat] #971691
04/12/11 08:24 PM
04/12/11 08:24 PM
michigan woods
michigan woods
sounds stupid,but are sure the rotor is turning while cranking? i had a dist gear/shaft fail once.
sounds like maybe the wiring to the orange box/dist/car is an issue? do you have a FSM? or wiring diagram to ck all the ign wiring?
some times i use a dist hooked to the system,but in my hand,and spin it,to see if the system is working.is any of the parts to be known to be good,from before?
ck pickup in dist,vs reluctor for clearance.should be .010 or less w/o hitting.
look into the tech archives for wiring,and electronic info,here is the wiring dia from there click on the link. http://www.moparts.org/Tech/Archive/elec/3.html
Re: some help starting new engine [Re: imfixinmopars426] #971692
04/12/11 09:12 PM
04/12/11 09:12 PM
california
drumcat Offline OP
drumcat  Offline OP
california
Rotor turns,Will Take a look at the diagram.
