Oil Slinger on a 383. Is it needed ? #971445
04/11/11 08:40 PM
04/11/11 08:40 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
I just pulled the timing cover on my 383 and there is no oil slinger on it. Is it needed ?
1969 Super Bee High School car I got back 2004 Ram 2500
Re: Oil Slinger on a 383. Is it needed ? [Re: runnerrt] #971446
04/11/11 08:47 PM
04/11/11 08:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If I pull one apart and it has it I use it.Ive seen quiet a few that didnt have the slinger.The new seals do a better job than they did 40 years ago.Rocky
Chrysler Firepower
Re: Oil Slinger on a 383. Is it needed ? [Re: runnerrt] #971447
04/11/11 08:47 PM
04/11/11 08:47 PM
Kirkland, Washington
Pacnorthcuda Offline
IMO---no. The timing chain gets plenty of oil, as does the oil pump eccentric cuz its on the back side of the cam sprocket.
The slinger IS needed on small blocks though--for the oil pump eccentric.
Re: Oil Slinger on a 383. Is it needed ? [Re: Pacnorthcuda] #971448
04/11/11 08:55 PM
04/11/11 08:55 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
Thanks. I will put it back together then
Re: Oil Slinger on a 383. Is it needed ? [Re: therocks] #971449
04/11/11 09:19 PM
04/11/11 09:19 PM
but use it if you have one in your stash
Re: Oil Slinger on a 383. Is it needed ? [Re: Pacnorthcuda] #971450
04/11/11 09:27 PM
04/11/11 09:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Fuel pump, man!
Re: Oil Slinger on a 383. Is it needed ? [Re: RapidRobert] #971451
04/11/11 09:28 PM
04/11/11 09:28 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
YES you should. EXCUSE the other responses ... they have been heavily
Re: Oil Slinger on a 383. Is it needed ? [Re: dOoC] #971452
04/11/11 09:31 PM
04/11/11 09:31 PM
YES YES!!! FUEL pump.....Fuel pump.....and I am only on my 2nd beer!!!
Re: Oil Slinger on a 383. Is it needed ? [Re: Pacnorthcuda] #971453
04/11/11 10:00 PM
04/11/11 10:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you look at the proper position of the installed slinger it does what it designed to do. It cups over the seal area keeping excess oil from the seal area. New technology seals do not really require it. This is true on the big or small block engines the amount of oil slung around by that slinger's smooth back side is negligible. There is enough oil thrown off the timing chain and oil fog out of the crankcase to keep any fuel pump eccentric or any other parts well lubricated. If they would have truly wanted oil to be thrown to various places by the slinger it would have been ribbed or veined to catch and throw the excess oil.
Put it together and don't worry about it. Some had them from the factory and some didn't. Not a big deal. Had a lot of motors apart and I great many didn't have one and I have never had a problem with a seal leaking with out one.
Re: Oil Slinger on a 383. Is it needed ? [Re: Pacnorthcuda] #971454
04/11/11 10:00 PM
04/11/11 10:00 PM
chicagoland,usa
chicagoland,usa
....... .....keep em comin'
Re: Oil Slinger on a 383. Is it needed ? [Re: MoparforLife] #971455
04/11/11 10:13 PM
04/11/11 10:13 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Some of youz guyz are missing the point .... the minor secondary "job" of this part is to "protect" the seal from excess oil.....
.... the main job is is to SLING oil up and around the timing chain and gears..... HENCE the name ...
New "tech" seals? .....
Re: Oil Slinger on a 383. Is it needed ? [Re: dOoC] #971456
04/11/11 10:39 PM
04/11/11 10:39 PM
Upper Midwest
Upper Midwest
If it's main intent was to sling oil it would be ribbed or veined to catch oil to sling it. It is not it is smooth. Main purpose is to keep excessive oil that has been thrown off the timing chain and from the oil fog from the crank case for accumulating around the seal area causing a leak. No more oil is needed in this area.
To each their own belief. If you believe you need it use it. Do what you want but if you leave it off don't loose any sleep over it you will not cause a difficulties or damage.
Re: Oil Slinger on a 383. Is it needed ? [Re: MoparforLife] #971457
04/11/11 10:42 PM
04/11/11 10:42 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
..... all I can say is this....WHY did the engineers at Ma-Mopar call it a slinger then ?
Re: Oil Slinger on a 383. Is it needed ? [Re: dOoC] #971458
04/11/11 10:52 PM
04/11/11 10:52 PM
Upper Midwest
Upper Midwest
Dam good question because it is shielding a heck of a lot more than slinging. They function to the front cover seal much like the rubber umbrella
Like I said do what you please. If you have one use it. If you have it together leave it alone unless it really bothers you.
Re: Oil Slinger on a 383. Is it needed ? [Re: MoparforLife] #971459
04/11/11 10:58 PM
04/11/11 10:58 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Good question ? ....
If it was more a shield than a slinger ...why-then didn't the college-educated engineers call it an OIL SHIELD then ?
Re: Oil Slinger on a 383. Is it needed ? [Re: MoparforLife] #971460
04/11/11 10:59 PM
04/11/11 10:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
By the mid 70's most engines small or big block never had them. If you have it use it if you dont have one run as is.
Re: Oil Slinger on a 383. Is it needed ? [Re: dOoC] #971461
04/11/11 11:30 PM
04/11/11 11:30 PM
Upper Midwest
Upper Midwest
If the umbrella seal on a valve stem doesn't seal squat, rather it shields the valve guide from excessive oil so why do they call it a seal??? The slinger and that umbrella seal do the same thing. They keep oil from accumulating. put it in, leave it out, go to bed and don't loose any sleep either way. Good night.
Re: Oil Slinger on a 383. Is it needed ? [Re: MoparforLife] #971462
04/12/11 02:22 AM
04/12/11 02:22 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
OMG ... umbrella seal .... shield ? ... ...what were you to "create" that ...
Have a ...and call CTC in the morning ...and then argue with THEM ! THAT beez the Doc's Rx !
Re: Oil Slinger on a 383. Is it needed ? [Re: runnerrt] #971463
04/12/11 09:52 AM
04/12/11 09:52 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Has ANYONE ever heard of any engine tossing its cookies and the owner saying it was because he didn't use an oil slinger???
Just the same I use it for no other reason that it makes ME feel better. I'm sure it's purely psychological.
Re: Oil Slinger on a 383. Is it needed ? [Re: runnerrt] #971464
04/12/11 12:38 PM
04/12/11 12:38 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I put my 400 together in Feb. '94. I had a slinger, but forgot to put it in. I didn't bother pulling the timing cover to install it. No problems here.
