Oil Slinger on a 383. Is it needed ?
#971445
04/11/11 08:40 PM
04/11/11 08:40 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
I just pulled the timing cover on my 383 and there is no oil slinger on it. Is it needed ?
1969 Super Bee High School car I got back
2004 Ram 2500
Re: Oil Slinger on a 383. Is it needed ?
[Re: runnerrt]
#971446
04/11/11 08:47 PM
04/11/11 08:47 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
If I pull one apart and it has it I use it.Ive seen quiet a few that didnt have the slinger.The new seals do a better job than they did 40 years ago.Rocky
Chrysler Firepower
[Re: Pacnorthcuda]
#971450
04/11/11 09:27 PM
04/11/11 09:27 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
IMO---no. The timing chain gets plenty of oil, as does the oil pump eccentric cuz its on the back side of the cam sprocket.
The slinger IS needed on small blocks though--for the oil pump eccentric.
Fuel pump, man!
[Re: dOrk !]
#971452
04/11/11 09:31 PM
04/11/11 09:31 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
YES you should. EXCUSE the other responses ... they have been heavily
YES YES!!! FUEL pump.....Fuel pump.....and I am only on my 2nd beer!!!
[Re: MoparforLife]
#971455
04/11/11 10:13 PM
04/11/11 10:13 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
If you look at the proper position of the installed slinger it does what it designed to do. It cups over the seal area keeping excess oil from the seal area.
Some of youz guyz are missing the point .... the minor secondary "job" of this part is to "protect" the seal from excess oil.....
.... the main job is is to SLING oil up and around the timing chain and gears..... HENCE the name ...
New "tech" seals? .....
[Re: MoparforLife]
#971459
04/11/11 10:58 PM
04/11/11 10:58 PM
dOrk !
Florida STAYcation
Dam good question because it is shielding a heck of a lot more than slinging.
Good question ? ....
If it was more a shield than a slinger ...why-then didn't the college-educated engineers call it an OIL SHIELD then ?
[Re: dOrk !]
#971461
04/11/11 11:30 PM
04/11/11 11:30 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If the umbrella seal on a valve stem doesn't seal squat, rather it shields the valve guide from excessive oil so why do they call it a seal??? The slinger and that umbrella seal do the same thing. They keep oil from accumulating. put it in, leave it out, go to bed and don't loose any sleep either way. Good night.
