very strange ingition problem with 440 #971310
04/11/11 06:34 PM
04/11/11 06:34 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
Hey all
have this problem and i think i may have a bad ingition control module, i hooked up my meter to the coil and with the car running it is only showing about 7 volts. shouldnt it be more like 11-12V ?
when i increase the rpms in park it revs just fine, but when i put a load on it (driving) the motors pops and its like its dragging a house. This is a new motor and has had this problem since day one. could a bad module cause the lack of power?
Re: very strange ingition problem with 440 [Re: AK_JH27] #971311
04/11/11 07:12 PM
04/11/11 07:12 PM
I'd say not the module. Check plugs/wires/rotor phasing/vac leak
Re: very strange ingition problem with 440 [Re: RapidRobert] #971312
04/11/11 07:17 PM
04/11/11 07:17 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
never heard of rotor phasing, whats that?
Re: very strange ingition problem with 440 [Re: AK_JH27] #971313
04/11/11 07:34 PM
04/11/11 07:34 PM
ahhh Rotor Phasing, one of my (two) Mopar obsessions. Due to stackup of tolerances when it fires the rotor may b just far enough away from the underside of the dist cap terminal that it misfires under load but OK w no load. check by drilling a 1/2" hole in the top flat of the dist cap 2/3 of the way between the center terminal and the #1 terminal closer to the #1 terminal and shine your timing light down on it at a high enough rpm where the mechanical slots are maxed out and at a high enough vac (low load which is not to b confused w the high load that it misses at) so that the vac adv is maxed also & see how far the metal rotor blade tip is from the underside of the #1 cap terminal at speed and note that vac adv shifts phasing opposite the direction of rotor rotation. It is set in stone but can b changed by modding some parts and does not change w timing but vac adv does change it. This hole also vents ionized air which slightly contributes to misfire like the air space under a tree struck by lightning becomes electrified. If the distance is too great it will miss under load just like a plug w way too much gap but I'd check the others first. Holler when you discover what it is
Re: very strange ingition problem with 440 [Re: AK_JH27] #971314
04/11/11 07:43 PM
04/11/11 07:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not to disagree with Robert, as he might be right, but you should be a 12-14 volts and it is the job of the voltage regulator to maintain that.
Re: very strange ingition problem with 440 [Re: mikemee1331] #971315
04/11/11 08:06 PM
04/11/11 08:06 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I believe with the engine running the coil voltage is supplied through the ballast resistor. Therefore depending on the resistor the voltage will be less than 12V. 7V may actually be ok.
Re: very strange ingition problem with 440 [Re: AK_JH27] #971316
04/11/11 08:08 PM
04/11/11 08:08 PM
Under My Car
Mopar_Country Offline
Under My Car
Hey all
have this problem and i think i may have a bad ignition control module, i hooked up my meter to the coil and with the car running it is only showing about 7 volts. shouldn't it be more like 11-12V ?
when i increase the rpm's in park it revs just fine, but when i put a load on it (driving) the motors pops and its like its dragging a house. This is a new motor and has had this problem since day one. could a bad module cause the lack of power?
If you are running a ballast resistor that would be about right 7-9 volts. It should get a full 12 volts when cranking and the run circuit drops to a lower voltage.
Re: very strange ingition problem with 440 [Re: TooMany62s] #971317
04/11/11 09:32 PM
04/11/11 09:32 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Actually they generally do run higher than 7v it depends on:
engine RPM
what resistance the ballast happens to be in this import world
what coil you are running and even a stocker may be "slightly hotter" one out of 100, etc
This is strickly a function of:
How good the wire connection is through the bulkhead to the ign switch, although the regulator (which "senses" off this line) is going to TRY and keep it at 14V running
RPM, which changes the duty cycle of the on/ off pulse, which is what you are reading the "average of"
The resistance of the ballast, AND it's temperature characteristics. I frankly doubt--with the stories we hear about ballast failure rates nowadays---that they are 'what hey once were'
The current draw of the coil you are running The more current the coil draws, the lower it pulls the voltage reading. "Ohm's law."
This voltage has nothing to do with rotor phasing
(Bad) rotor phasing is quite simply that the points/ pickup/ advance system causes the spark to occur when the rotor is coming around NOT pointing to the tower contacts.
Frankly I think this is over rated. A SIMPLE WAY to tell if you have a big phasing problem is SIMPLY LOOK INSIDE THE CAP. If you see "carbon tracks" either "leaving" or "approaching" the cap contacts, then you definately have a problem.
Re: very strange ingition problem with 440 [Re: Yancy Derringer] #971318
04/11/11 11:29 PM
04/11/11 11:29 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Best way to check it is with the key on and eng off. This way the current is flowing to ground and with a standard Mopar electronic ign and a ballast you should see about 6 or 7 volts. One big factor with the eng running is dwell time. Everytime the ECU opens the coil ground (fireing plugs) you will see 12 volts at the coil and when its grounded you will see about 6 or 7 on the coil + and 0 volts on the coil - side. So with the eng running this happens so fast you get an average of the 2 readings. Also how hot the ballast is makes a small difference. Test it with the key on eng off. Ron
Re: very strange ingition problem with 440 [Re: Yancy Derringer] #971319
04/11/11 11:50 PM
04/11/11 11:50 PM
That's not what I said, My phasing suggestion was a possible explanation for why it is not running right under load which he could take or leave. Yancy how did you get that word in your post that big? If I ever get as rude and egotistical as you are I may need that information. It's too bad the Mods dont have the stones to stop some of the nonsense going on here but something trivial like a miscategorized post they are all over that in a heartbeat and I know for a fact Yancy that some people will not post while you are lurking nearby as they dont feel like being jumped on
Re: very strange ingition problem with 440 [Re: RapidRobert] #971320
04/12/11 12:04 AM
04/12/11 12:04 AM
Montana
Y
Y
Montana
Rapid don't get your thingie in a knot. I just meant that phasing had nothing to do with the voltage problem, end of story. End of story. Once again, end of story. I wasn't claiming that phasing may or may not be PART of the problem, only that if it was, it was unrelated to the voltage. End of story. REALLY end of story
There is no nonsense going on here. I am simply telling him what it is, end of story. End of story. End of story.
What do you car how big "the word" is? It was simply meant to be a humorous accent to the posters words.
THIS means that you think the poster actually knew what he was talking about.
Believe me buddy, if I tell you to 'eff off' THAT is what I'll tell you. I won't be dancing around the word in some sideways manner. So don't get all rile up when there is nothing to get riled up ABOUT
I've never told anybody this before, but I'll tell you now. "You need to consider taking a chill pill."
Re: very strange ingition problem with 440 [Re: Yancy Derringer] #971321
04/12/11 01:07 AM
04/12/11 01:07 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
So I'm thinking that "the word" was a jpg or similar inserted.
Maybe an IMG from a hosting site???
Just guessing. It took me a few tries to get a sig pic to work at all. That is about my understanding of computers.
I want my fair share
Re: very strange ingition problem with 440 [Re: 383man] #971322
04/12/11 06:14 AM
04/12/11 06:14 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Doesn't the coil draw voltage even when the engine is not running?
Re: very strange ingition problem with 440 [Re: AK_JH27] #971323
04/12/11 01:27 PM
04/12/11 01:27 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
Thanks guys, this at least gives me some direction on trying to solve this problem, i will report this weekend on what i find.
