Curse of the leaky master cylinder cover
#97110
07/30/08 01:04 PM
07/30/08 01:04 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I have a manual disk brake master on my duster. Its a reman unit and it works properly however when driving the car, fluid sloshes out of the top (I think).
Thank god I'm using DOT 5!!!
Anyway, I tried different covers and a different rubber gasket with no change.
So I pulled the master and thinking that the rim on the top was pitted I "machined" the top with sand paper on a granite block. As it cut I could see gaps where it was uneven and stopped only when I go all clean metal.
I crimped the bail wire to shut tighter.
The darn thing still leaks!!! Any tips. I don't know where to go from here.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Curse of the leaky master cylinder cover
[Re: Y3 70 BEE]
#97112
07/30/08 02:23 PM
07/30/08 02:23 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Is there anything unique about the 1972 A body system?
I ask this because I've read a couple threads with this same concern, they were also 72.
Had a Dart years ago. Many attempts at solving the same issue. It was also a power brake 72.
[Re: Y3 70 BEE]
#97115
07/30/08 03:07 PM
07/30/08 03:07 PM
Posts: 419 NY
F1Scamp
NY
We had the same thing on the AAR, put two different re-man units on. We bought a brand new one and haven't had a problem since.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: F1Scamp]
#97116
07/31/08 08:00 AM
07/31/08 08:00 AM
CJK440
Ansonia, CT
I popped the cover last night, that was untouched after my testdrive following the resivoir resurfacing. Both resivoirs are level.
If it was transfering fluid by way of a bad piston and overfilling one resivoir, wouldn't one be filled to the brim??
I think I am going to replace it to get a smaller bore master to help with pedal effort anyway. I'll get a new one and hopefully be done with it.
